Veneer
Forum topic by Adventurer posted 35 days ago 110 views 0 times favorited 5 replies Add to Favorites
View Adventurer's profile
Adventurer
15 posts in 36 days
35 days ago
Topic tags/keywords: question
Hello there,
Can I use my 10” table saw to make veneer, as I don’t have band saw?
Thank you
View Eric's profile
Eric
629 posts in 225 days
35 days ago
Sure. For that matter, you can use a handsaw. That’s what I do.
-- Eric at http://adventuresinwoodworking.com
Adventurer
15 posts in 36 days
35 days ago
thanks Eric,
But I am afraid I didn’t ask my Q in the right way!
I mean can I slice veneering from Hard wood using my table saw instead of band saw?
View motthunter's profile
motthunter
1154 posts in 240 days
35 days ago
You can.. but remember how thick the kerf of the table saw blade is. You get more waste on the table saw. Also, you are limited to less than half the width of your table saw. You may get veneers that are only 4 to 4.5 inches wide with a 10 inch blade. Lastly, remember to leave enough wood for sanding to get your veneers smooth by sanding later
-- making sawdust....
View Loren's profile
134 posts in 89 days
35 days ago
If you are planning to make veneer from 4/4 stock you’ll find
it challenging to get more than 3 leaves from each board
with a table saw. With a band saw you can get 4 or more
so you can do fancier bookmatching.
In a pinch though the table saw is fine. I use it for resawing
often, even though I have a couple of nice band saws. The
reason – the bandsaws are usually a little tweaky and the blades
less sharp than is ideal for sawing veneers. You’ll generally
want to use a new blade for resawing on the bandsaw – plus
fiddle with the saw to make sure the cut goes smoothly.
-- Need help with marketing your business? Look in my profile.
Adventurer
15 posts in 36 days
33 days ago
got it thank you every one
Bookmark And Share This Page
