I need advice about spar and plywood for outdoors.
Forum topic by RussellAP posted 08-18-2012 04:01 PM 839 views 0 times favorited 9 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2286 days
08-18-2012 04:01 PM
Back in March this year I bought a 8’x10 shed. I didn’t have any time to put it together and it got really hot so I let it sit. Now I’m going to put it together.
I got some 4 inch cinder blocks to put down on the ground first in a outline of the shed and some under it where the 4×4’s will sit on top and some 2×4’s to make a frame for the plywood.
The plywood is laying out in the driveway and I’ve sparred the top and sides and sealed them up real good.
My question is, should I seal the other side, or do I need to let it breathe on one side?
9 replies so far
10398 posts in 3647 days
#1 posted 08-18-2012 05:25 PM
You can seal the unfinished side if you want. In an unsupported
panel finished on one side only will warp due to uneven moisture
absortion on the finished vs unfinished side.
I would finish it, personally. Paint it if you want. White paint
inside a shed can make it easier to see in there.
RussellAP
#2 posted 08-18-2012 05:28 PM
Loren, I’m not worried about warping, it will be screwed down to a frame. I just wondered if the up side of the sheet needed treating seeing it’ll be on the inside of the shed and all. I guess I could assemble the base of the shed and roll the paint on that way. I just need to get this thing put together because I have stuff all over the yard, three ladders, yard equipment and I’d like a place to store some of my chairs this winter.
View Bill White's profile
Bill White
4931 posts in 3960 days
#3 posted 08-18-2012 05:36 PM
Russell, Shame on you for working on your chair business when ya shoulda been puttin’ the shed together. (Jokin’ of course.)
Might wanna put some heavy mil plastic down on the ground before the flooring goes in. It’ll keep the moisture somewhat controlled. Just a thought.
Bill
-- bill@magraphics.us
117091 posts in 3576 days
#4 posted 08-18-2012 05:39 PM
You don’t need to use spar varnish inside primer& paint won’t hurt on both sides. I would use 6” blocks and put down a 6 mil vapor barrier on the ground before build your storage unit. plywood does not need to breathe .
Edit
looks like Bill and I were typing the same thing at the same time LOL
RussellAP
#5 posted 08-18-2012 05:47 PM
Good to know guys, I happen to have some 4 mil polyethylene on hand.
Jim, I already have the blocks, I think that 4” and then a 4×4 frame on top of that is high enough off the ground, I don’t want to have to build steps.
Also the bottom will be very open for air flow.
#6 posted 08-18-2012 05:52 PM
when you have only 4” you will have more ground contact for your wood. Another point is that 4×4s are not meant to be horizontal structural members. If you use 6” blocks all you will need for a step is some 8” blocks laying their side for steps .
RussellAP
#7 posted 08-18-2012 06:26 PM
Jim, the blocks are only an outline of just under the 4×4’s, it’s not a solid block floor. I’m just using them to get it up off the ground. I think with the polyethylene under it, it should do okay. The base is likely to outlive the shed.
#8 posted 08-18-2012 06:33 PM
Yes Russ I understand, that part of your construction is fairly standard. I think I’m being a building snob so I’ll stop harassing you. I know you will build it the way you have planned ,like most of us would. I hope it goes together for you quickly and holds up well.
RussellAP
#9 posted 08-18-2012 06:38 PM
I must admit, I’ve been a bit intimidated with the thought of assembly which is the main reason I’ve put it off. The ground where I’m putting it tends to be soggy when it rains a lot, but it’s bone dry now. We live on a slab of clay that drains very slowly, however the area I’ve chosen is not so bad as the rest of the yard, so I think with that poly under it and the treated wood on top of blocks, (and yes, I do have a roll of styro to put down under the wood), the base will outlast me.
