What dose
Forum topic by Andrew Betschman posted 08-18-2012 12:01 PM 956 views 0 times favorited 4 replies Add to Favorites Watch
View Andrew Betschman's profile
Andrew Betschman
309 posts in 3131 days
08-18-2012 12:01 PM
a board foot of cherry weight approx.
-- Andrew, Ohio https://www.etsy.com/shop/AndrewBetschman
View KnickKnack's profile
KnickKnack
1088 posts in 3474 days
#1 posted 08-18-2012 12:10 PM
I don’t use “board feet” so I can’t help on that front.
However, there’s a density chart here (which site also has a moisture content variation table), and another here.
From this one ought to be able to work out the weight of a piece of wood (board foot?) of known volume.
Hope that helps.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View AandCstyle's profile
AandCstyle
2978 posts in 2165 days
#2 posted 08-18-2012 02:39 PM
I found one reference indicating that cherry weighs 35 lbs/cubic foot. That would make 1 bf approximately 3 lbs.
-- Art
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#3 posted 08-18-2012 05:50 PM
Actually it is closer to 2 lbs due to the fact that wood is sold nominally and a 4/4 board is only 13/16” in actual thickness generally.
Here is the math.
Density black cherry = 33.34 lbs/cu.ft / 12 = 2.78 lbs per actual board foot X .8125 = 2.26lbs/ nominal bf
My density source came from this chart.
-- Bondo Gaposis
AandCstyle
#4 posted 08-18-2012 11:15 PM
Yeah, I thought of that, but OP didn’t indicate if it was rough or s2s or whatever. It would also vary with moisture content, heart or sap wood content, etc. He, also, didn’t indicate any particular species of cherry, so it might be Brazilian cherry which would be more than 5 pounds /bf. FWIW
-- Art
