| Forum topic by newwoodbutcher | posted 277 days ago | 1613 views | 0 times favorited | 11 replies | ![]() |
277 days ago |
I’m planning to build a 120 ft three tie high retaining wall as well as a few road curbs flower beds and steps with RR Ties. What ’s the best tool for cutting the ties? I’m thinking that using a chainsaw will ruin the chain at some considerable cost. I cut one with a sawzall but it wasn’t easy or very accurate. I’m thinking a 12” circular saw or a portable band saw from Craig’s List might be my best choice. I’m thinking the pitch and sand in the ties will dull any blade pretty quickly. Is it worth it to buy cheap carbide blades and just plan on wasting them? Or steel blades? What are you folks experience? Any advice would be appreciated -- Ken |
11 replies so far
#1 posted 277 days ago |
A 20” chain for a chain saw is about $14. Can you buy any other blade any cheaper and sharpen it repeatedly? There’s no easy way to cut coated ties. One thing I should mention, check with the local authorities. When I lived on US2 in Montana and used old ties for a retaining wall on the front yars, the state made me get rid of it because of the chemicals in the wood. -- Improvise.... Adapt...... Overcome! |
#2 posted 277 days ago |
So you would use a chain saw? How long will it cut before it needs to be sharpened/replaced? -- Ken |
#3 posted 277 days ago |
Most guys who do a lot of this use a 16” Japanese |
#4 posted 277 days ago |
Over the years I have installed hundreds of old railroad ties in building parking lots and campsite areas, and we always used a chain saw to cut them. If you are using used ties, it pays to look each one over in the area you plan to cut to remove small rocks, and also look for the occasional piece of iron. As I recall, we could go a day on one sharpening if we didn’t hit any major rocks or anything. |
#5 posted 277 days ago |
You can keep a chain pretty sharp touching it up with a file. If you are careful and keep it consistent, it will start cutting a curve. Use a guide if necessary or you haven’t done much filing. -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#6 posted 276 days ago |
The chemicals in the wood burns your skin !!! iI built a wall outta them on a hot day wearing shorts using a chainsaw. Sure glad the lake was near by. Lesson learned the hard way. -- What started as a hobbie is now a full time JOB! |
#7 posted 276 days ago |
Thak you all. I wouldn’t have thought the chainsaw was the best choice all on my own. -- Ken |
#8 posted 276 days ago |
Wear a helmet with a face shield when doing this. ties get gravel pressed into them since they lay on a gravel bed when in use to hold rails. You will encounter an ocassional gravel and it can be thrown by the chain. I agree that the chain saw is the best tool. |
#9 posted 276 days ago |
Ken -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#10 posted 276 days ago |
Guys that install tie walls use a chainsaw motor with a special ‘tie cutter’ circular blade. I have rented these and they work really well. Call around your local tool rental places. You will dull/ruin a chain in minutes cutting railroad ties. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#11 posted 248 days ago |
Used to heat my home with ties (long time ago in very rural area…the deer never seemed to mind), and used a 24” saw blade mounted on a steel frame and driven from the tractors power take off. You can cut a mess of ties and once you’ve cut a truckload of ties you need a break so you touch up the blade. It worked great, when I moved I gave the saw to a buddy. As far as I know he’s still using it. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3548 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
809 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
