Advice on how to taper without a thicknesser?
Forum topic by CplSteel posted 08-17-2012 08:38 PM 1351 views 0 times favorited 4 replies Add to Favorites Watch
View CplSteel's profile
CplSteel
142 posts in 2186 days
08-17-2012 08:38 PM
Topic tags/keywords: question taper angle
The project I am working on requires 4 circle-ish shapes that are about 6 inches in diameter and the thickness tapers from 3/4” to 1/32” or so. I am using poplar because this part will not be seen, but it will act as a spacer between two pieces of oak. If that was not clear, perhaps this would help: If I had a thickness planner I would shim up a board to give me the angle/taper I needed and then use that as the reference surface for my pieces.
As I do not have a thicknesser, I tried to use handplanes but removing that much material is taking a whole lot of work and clamping it is tough as I am trying to taper the face of the board. When I shim it up, to get the line I want to be flat, the support below the piece is not great, the thin edge is hard to register against a dog or stop without the stop getting in the way of the plane. Handplanes seem to be a no go as the piece is just too thin on one end to clamp safely and still give me access to the face of the board.
My only other thought is to rough cut off the waste (or most of it) with a handsaw (the piece is too tall to run through my bandsaw’s 4” resaw capability) and use a rasp or file to true the face.
Before I embark, any other ideas?
View PurpLev's profile
PurpLev
8536 posts in 3670 days
#1 posted 08-17-2012 08:45 PM
how about a router instead of a thicknesser? you can create a frame that will sit above your work piece. the work piece will lay underneath the frame and will be shimmed to give you the required taper. than using a router sled on the frame route the waste out. sort of like thicknessing end-grain cutting boards, only at a taper.
View madts's profile
madts
1862 posts in 2361 days
#2 posted 08-17-2012 08:47 PM
Belt sander with a coarse grit will take away most of the stuff.
-- Thor and Odin are still the greatest of Gods.
View OnlyJustME's profile
OnlyJustME
1562 posts in 2398 days
#3 posted 08-17-2012 10:09 PM
If you have a router you could make Stumpy’s horizontal router stand (or something similar) and use that. Would work great i think.
-- In the end, when your life flashes before your eyes, will you like what you see?
View BTimmons's profile
BTimmons
2303 posts in 2507 days
#4 posted 08-18-2012 01:52 AM
Build a router sled and elevate one side of the workpiece.
-- Brian Timmons - http://www.BigTWoodworks.com
