Pressure Treated Lumber NO-NO
Forum topic by Handtooler posted 08-17-2012 06:14 PM 3548 views 0 times favorited 6 replies Add to Favorites Watch
View Handtooler's profile
Handtooler
1497 posts in 2034 days
08-17-2012 06:14 PM
Brother and sister Lumberjocks, Just a heads up! Don’t wrap a pressure treated post or plank in an outdoor porject with aluminum sheetmetal. I replaced a support post in our breezeway this past spring and since we’ve had an extremely hot June this summer the wrap of white painted aluminum is now blistering, cracking and popping open. Looks a lot like a garden toad. It’s gonna be ugly by winter I suspect. I believe the culprit is the copper in the treatment solution is not compatable with the wrap. Russell
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Doss's profile
Doss
779 posts in 2166 days
#1 posted 08-17-2012 06:56 PM
Yes, you should be using copper, pvc, maybe galvanized in a pinch, or wrapping your PT lumber (they make asphalt, rubber, and other membranes for wrapping) if you want to use aluminum.
What you are experiencing is galvanic corrosion attacking the aluminum.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View Dallas's profile
Dallas
3599 posts in 2389 days
#2 posted 08-17-2012 07:49 PM
Well, at least you didn’t make an end grain cutting board for the local butcher shop!
View treaterryan's profile
treaterryan
109 posts in 2189 days
#3 posted 08-17-2012 07:51 PM
The copper is the culprit.
-- Ryan - Bethel Park, PA
Handtooler
#4 posted 08-17-2012 08:35 PM
Thanks Dallas, I appreciate your humor. And, I certainly wasn’t trying to be a smart * in my earlier post. Russell
View Dusty56's profile
Dusty56
11819 posts in 3590 days
#5 posted 08-17-2012 10:03 PM
The new and improved pressure treating chemicals….kinda makes you want to wear gloves when handling it , ay ?
View Jeff in Huntersville's profile
419 posts in 3096 days
#6 posted 08-17-2012 10:17 PM
It’s a small positive but you made yourself a free source of a very tiny amount of electricity.
