Having trouble figuring out what tool I can use, help!
Forum topic by AndrewTheWoodWorker posted 08-17-2012 09:14 AM 929 views 0 times favorited 6 replies Add to Favorites Watch
View AndrewTheWoodWorker's profile
1 post in 2041 days
08-17-2012 09:14 AM
Hey there everyone.
So, I make wooden jewelry, and I have some cool ideas for laminated pieces.
The thing is, for my ideas, I need to be able to cut 1.5 inch thick stock, to extremely thin slices. I’m talking 1mm thick.
I have been trying to find something that would enable me to do that. I’ve tried getting a bunch of different miter boxes, but they don’t work. I can’t get them to cut straight, no matter how much I fiddle with them.
I am low on money, so I’ve been trying to find a some what cheap way to do this.
I’ve thought about a miter saw, but the thickness of the blade would take up a lot of material. So for every lamination I get, I would lose two.
And I’m using very rare, expensive woods.
I think I may end up just having to buy a bandsaw.
Any suggestions on a remedy to my situation?
View bent's profile
311 posts in 3601 days
#1 posted 08-17-2012 10:22 AM
what if you used a spill plane? you’d get really thin pieces and not waste any material.
View dhazelton's profile
2719 posts in 2228 days
#2 posted 08-17-2012 12:51 PM
A band saw with a fine blade won’t do it for you? You can pick a small bench top model up for very little money.
View Lee Barker's profile
Lee Barker
2170 posts in 2782 days
#3 posted 08-17-2012 12:55 PM
I understand budget constraints, as I am sure all of us do. That said, a used scroll saw would not only give you the slices but also allow you to cut shapes in a block and then slice it, getting multiples and gaining time.
If you have a proven market for your wares and an adequate way to distribute them, I would think this would be worth considering.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View JesseTutt's profile
854 posts in 2042 days
#4 posted 08-17-2012 02:22 PM
It would help if you gave additional dimensions of the material you want to cut.
That said, how about “Rockler’s Miter Trimmer” (
For the last few years “The Woodworking Shows” had a person demoing how to make your own inlay. He had a device that used a razor blade to cut very thin strips of materials. One device cut stright strips and another allowed cutting curved strips.
#5 posted 08-17-2012 10:18 PM
“Forget the miter saw and bandsaw…”
Care to enlighten?
View CplSteel's profile
142 posts in 2096 days
#6 posted 08-17-2012 10:26 PM
Sounds like you are making cross cuts, not rip cuts and need them 1mm thick. I suggest a pull saw with a supper thin kerf. I have one no name brand pull saw that is pretty easy to keep straight if you score the cross grain first. As a bonus the teeth are fine so it leaves a pretty decent surface.
If you need them very thin, have you tried a handplane and a shooting board? You can get pretty decent shavings with a well tuned plane. Here I would go down the length of the board as opposed to a cross grain cut but you can get 1mm thick shavings if you wanted to.
