Solid wood grain orientation
Forum topic by siouxdawgs0409 posted 08-17-2012 12:44 AM 897 views 0 times favorited 3 replies Add to Favorites Watch
View siouxdawgs0409's profile
siouxdawgs0409
107 posts in 3062 days
08-17-2012 12:44 AM
Hello all…This may be a simple question for someone. I am building a small cabinet type porject. It has a solid wood top and bottom as well as sides and a back. The front contains two small doors that open. Approx size is 15 inches tall 31 wide and 19 deep. My plan is to run the grain from side to side on the top and bottom and then the sides will be run vertical so that the changes in moisture will allow all the wood to move together. The sides are going to be joined to the top and bottom with a routed dado in the top and bottom because the top and bottom are slightly larger and will hang over the side edge a few inches. What would the orientation on the grain on the back be? Vertical like the sides? And would a routed dado in the top and bottom with a rabet or mitre in the sides work to join it all together? Will this technique cause stress when the conditions change and the piece has movement? Thank you in advance.
3 replies so far
View HerbC's profile
HerbC
1744 posts in 2828 days
#1 posted 08-17-2012 01:18 AM
Are you going to use solid wood for the back? if so, rather gluing up a panel, use individual pieces, with shiplap joint to join the boards. Use small brads to attach the back boards. This will compensate for the wood movement in the back.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View JesseTutt's profile
JesseTutt
854 posts in 2079 days
#2 posted 08-17-2012 01:23 AM
If no one is going to see the back, then standard practice is to use a 1/4” plywood veneer for the back. You could use groves and rubber spacers to compensate for any movement of the sides.
siouxdawgs0409
#3 posted 08-17-2012 03:26 AM
Can the ship lap be mounted in a dado or rabbet at the top and bottom? Basically to hide the endgrain at the top.
