Strain or Tension?
Forum topic by Surfside posted 307 days ago 487 views 0 times favorited 11 replies Add to Favorites Watch
View Surfside's profile
Surfside
2317 posts in 371 days
307 days ago
I know most woodworkers use the term tension rather than strain. In sawmillcreek.org, a thread has been trending with comments regarding which is right, strain or tension? As a non-expert to the field, I would like to ask LJ’s regarding this subject and your knowledge. What do you think? Is tension and strain the same?
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
11 replies so far
View bondogaposis's profile (online now)
bondogaposis
1317 posts in 549 days
#1 posted 306 days ago
I use tension to distinguish it from compression.
-- Bondo Gaposis
View Nicky's profile (online now)
Nicky
430 posts in 2289 days
#2 posted 306 days ago
Non expert opinion…
I don’t think of tension and strain being the same in the context of wood.
Strain causes a board to warp or deform in someway (e.g. as it looses moister)
Tension is released when I cut a strained board, and this deforms my cutoff in someway.
But what do I know. My 2cents.
-- Nicky
View RickRogers7's profile
RickRogers7
37 posts in 1235 days
#3 posted 306 days ago
Tension or compression describe the load being applied to a particular item. Strain is a measure of how much that item deflects due to an applied load.
View JJohnston's profile
JJohnston
1401 posts in 1489 days
#4 posted 306 days ago
Strain is technically the amount of UNIT deformation (so much deformation per unit of length – think of it as “inch per inch”). The total amount of elongation or shortening is strain x the length of the member.
Tension is a force; its units are units of force, like pounds. It causes a tensile stress which is a function of the cross-sectional area of the member (stress = force divided by area, for lb/sq. in.)
-- My broker promised me he would treat my money as if it were his own. Trouble is, he did.
View Dusty56's profile
Dusty56
10727 posts in 1885 days
#5 posted 306 days ago
World English Dictionary
tension (ˈtɛnʃən)
— n
1. the act of stretching or the state or degree of being stretched
2. mental or emotional strain; stress
3. a situation or condition of hostility, suspense, or uneasiness
4. physics a force that tends to produce an elongation of a body or structure
5. physics a. voltage, electromotive force, or potential difference b. ( in combination ): high-tension ; low-tension
6. a device for regulating the tension in a part, string, thread, etc, as in a sewing machine
7. knitting the degree of tightness or looseness with which a person knits
[C16: from Latin tensiō, from tendere to strain]
strain/strān/
Verb:
Force (a part of one’s body or oneself) to make a strenuous or unusually great effort.
Noun:
A force tending to pull or stretch something to an extreme or damaging degree.
A breed, stock, or variety of an animal or plant developed by breeding.
Synonyms:
verb. stretch – filter – tighten – tense
noun. stress – tension – race
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View DylanC's profile
DylanC
82 posts in 872 days
#6 posted 306 days ago
RickRogers has it…Strain is a measurement of how much something is stretched. That’s the engineering definition, by the way. Common woodworing context may be different. The behavior Nicky is describing (a board warping after it is cut) is something that metals to also and is cased by residual internal stress.
-- Dylan C ...Seems like all ever I make is sawdust...
JJohnston
#7 posted 306 days ago
No, what he defined is deformation, and deformation and strain are not the same thing.
http://www.mechatools.com/en/definition.html
Surfside
#8 posted 306 days ago
So, when does strain apply when we deal with band saw blades?
JJohnston
#9 posted 305 days ago
I’m not sure what you mean. The blade manufacturer has (probably) an allowable tensile stress on the blade material. That and the cross sectional area determine the allowable tension. The strain is what it is; in this application, it doesn’t seem to me to be important to know it.
I can tell you, for example, where it would be important to. I’m a bridge engineer, and sometimes, we want to know the actual stress on a member in service, so we put strain gauges on it. We measure the strain, and using these relationships between force, area, stress and strain, we can calculate the actual stress on it.
Surfside
#10 posted 303 days ago
As you’ve mentioned that strain is the amount of unit of deformation or elongation, wouldn’t elongation or deformation happen in a band saw blade? I think this is what I was supposed to ask.
JJohnston
#11 posted 289 days ago
Yes, yes it would.
