type of finish and glue for trivets
Forum topic by grace123 posted 08-16-2012 03:25 PM 1943 views 0 times favorited 5 replies Add to Favorites Watch
View grace123's profile
grace123
228 posts in 2638 days
08-16-2012 03:25 PM
I am planning to make trivets for Christmas gifts. Yes I know it is August, but …. Does anyone have experience, good or bad, with using a finish? Using a trivet with no finish at all is going to do the job of protecting a tablet or counter from a hot pan. I don’t want to have any type of the finish melt onto the bottom of a pan. Suggestions?
Also, I am planning end grain cut off in a pattern for the trivets. Has anyone had experience, good or bad, with any of the glues?
Thanks.
5 replies so far
View PocketsFullOfSawdust's profile
8 posts in 1970 days
#1 posted 08-31-2012 02:51 AM
I don’t have experience or testing for trivets but for glue, I’d say Titebond III. I use it when I’m not sure. The other option is epoxy. As for finish, I’d probably recommend an oil or maybe Waterlox ( www.waterlox.com ).
Good Luck
-- "I think that if I did not work with wood, my life would be a hollow emptiness." Jonas Wainwright
View Edziu's profile
Edziu
151 posts in 2926 days
#2 posted 08-31-2012 02:59 AM
I would recommend the Titebond III (3) because it passes the ANSI Type One Test: AKA: “Boiling Water Soak.”
In other words, it deals well with heat, and moisture, two things a trivet/hot plate will most likely encounter.
See the video I learned this from here: http://www.youtube.com/watch?v=UNo66AFbZOo&list=UU84kr2zOvY6Pyfnv8yYdQRA&index=10&feature=plcp
View lumberjoe's profile
lumberjoe
2894 posts in 2124 days
#3 posted 08-31-2012 03:19 AM
I’ve often wondered about heat resistant finishes as well. My wife wants a couple nice trivets. Would a phenolic resin modified tung oil (waterlox or Rockhard) work well? I can’t imagine polyurethane or shellac would hold up for long.
View CplSteel's profile
CplSteel
142 posts in 2040 days
#4 posted 08-31-2012 07:32 AM
Poly is actually supposed to be quite good at dealing with heat.
View kepy's profile
kepy
293 posts in 2149 days
#5 posted 08-31-2012 11:40 AM
I have made a lot of scrolled trivets and just finished them with a mineral oil soak, then let them drain and dry and buff with a brown paper bag. Have one on my table that has been used for several years and still looks good. Most of the ones I gave as gifts wound up on the wall rather than the table.
-- Kepy
