I want to make a new tri-angle veterans flag box
Forum topic by Emma Walker posted 279 days ago 862 views 1 time favorited 18 replies Add to Favorites Watch
View Emma Walker's profile
Emma Walker
540 posts in 280 days
279 days ago
Topic tags/keywords: veterans triangle flag box
My Great, great grandpa was in WWII and died 31 years ago. My Great, great grandma just died and my Great grandma was going to take this to the VFW to have it burned! I said “the #*@% you will”... So I grabbed it and ran out the door. I don’t know what these are called and I want to get ideas on making a new box for the flag. The one it’s in now is all twisted and the joints are all pulled apart. I’m guessing that there are plans on the internet for these but I need to know what the name of them are.
Is it patriotically ethical to this?
-- I'm a twisted 2x4 in a pile of straight lumber.
18 replies so far
View MichaelT77's profile
MichaelT77
57 posts in 281 days
#1 posted 279 days ago
It’s a flag display case, and there’s certainly nothing wrong with building a new one.
I found a few examples on the Internet (http://www.united-states-flag.com/displaycases.html). I would imagine that finding plans would not be difficult.
-- Michael T, Pittsburgh, PA
View jmos's profile
jmos
637 posts in 539 days
#2 posted 279 days ago
About a month ago this project was posted http://lumberjocks.com/projects/68741
I’m sure Bob would be happy to help with dimensions or resources.
I can’t imagine there would be an ethical problem providing a nicer cabinet for the flag.
-- John
View Jamie Speirs's profile
Jamie Speirs
3679 posts in 1026 days
#3 posted 279 days ago
I always think things can be fixed
It would be nice to keep the box as
it is part of your family history.
It could have brass plates put on the
corners and brass is easily worked.
Take it apart and try and flatten it.
Put your name and restoration date on
the inside. Alternately used the existing
timber laminated to new timber.
I think this treatment of the flag by
Americans is such a wonderful tradition.
I would like to see the final project either
way
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Emma Walker
#4 posted 279 days ago
Maybe I could make a display case to keep the original display case in. After all the case is half of the memorabilia.
View MagGeorge's profile
MagGeorge
53 posts in 327 days
#5 posted 279 days ago
Brilliant idea to keep the original display case. It is keeping the legacy alive.
View dpwalker's profile
dpwalker
184 posts in 1001 days
#6 posted 279 days ago
Woodsmith Magazine has a very nice flag display table in issue #201. Very good looking with brass trim. the dipsplay case can also be stand alone.
-- I intend to live forever. So far, so good.
View 47phord's profile
47phord
136 posts in 406 days
#7 posted 278 days ago
Rough Cut with Tommy Mac did an episode on this a while back, you could probably find his plan there. As far as tossing the old case goes, don’t sweat it-the honor is in the flag, not the case it is stored in (excluding any sentimental value of course).
View Sawdust4Blood's profile
Sawdust4Blood
321 posts in 1191 days
#8 posted 278 days ago
You can see two different flag cases I have made here and here
The dimensions of the box are a function of the size of flag that you have but there are several different standard flag sizes so you need to make sure that you build the correct size box for the flag you have.
I like the idea of first trying to restore the original case but if it is warped or twisted, I think that you will find it very difficult to repair because the it’s already been cut to final sizing and you can’t re-dimension it to flatten the wood because then your box won’t be correctly sized for a proper fold of the flag.
They’re not complex to make but cutting the angles exactly for nice tight fitting miter joints can be challenging. Adding splines to the miter joints will help to keep them from coming apart again in the future.
-- Greg, Severn MD
Emma Walker
#9 posted 278 days ago
Those are incredible!
I’m thinking that I should put this project off until I master bird house building.
Sawdust4Blood
#10 posted 278 days ago
I wouldn’t necessarily say that you should put it off Emma. Making flag boxes are good skill building projects and they don’t require a huge investment in either a lot of lumber or specialized machines. Don’t try your first one with expensive exotic hardwoods but they don’t have to be because you’re trying to highlight the flag rather than the box. Go ahead and give it a shot. Even in the worst case, you’ll come away having learned some things about technique without a major investment in material.
-- Greg, Severn MD
Emma Walker
#11 posted 278 days ago
Sawdust4blood:
I guess if I screw it up it’s not going to be the end of great, great grandpa’s flag. I can always put it back in it’s old case again and try again later.
edit:
Why doesn’t this forum have a quote function?
View Moron's profile
Moron
4436 posts in 2063 days
#12 posted 278 days ago
a dignified end to a noble cause
Emma Walker
#13 posted 278 days ago
Moron: [a dignified end to a noble cause]
I have no idea what that means.
Sawdust4Blood
#14 posted 278 days ago
Give it a shot and good luck. If you run into any areas that give you problems, feel free to give me a shout or there are hundreds of folks here that know more than me who will also be willing to help you work through it.
-- Greg, Severn MD
View DYankee's profile
DYankee
2780 posts in 731 days
#15 posted 278 days ago
First – no it is not un-patriotic to re-box the flag.
The case is relatively easy – I’ve made several.
The top miter is a simple 45-degree, and the two bottom ones are basic 22.5-degree.
I’ve made them with the glass daddoed in, and with “oversized” facing to hold it in. Both are pretty straighforward, though the oversized facing is easier to finish.
The back is basic rabbet with 1/4” ply.
One key thing though – finish the inside with poly or like finish as acid in wood can rot flag.
-- Shameless - Winner of two Stumpy Nubs Awards
