Vega Pro 40 Table saw Fence Issue
Forum topic by TheRookieJer posted 08-16-2012 12:36 AM 1470 views 0 times favorited 2 replies Add to Favorites Watch
View TheRookieJer's profile
9 posts in 2306 days
08-16-2012 12:36 AM
Topic tags/keywords: tablesaw fence vega
So… I am a novice. Hence the name. I am having trouble with my new Vega Pro 40 table saw fence upon installation.
Here goes…
When the fence/head unit is resting on the front rail/tube, it wiggles around about 1/16 of an inch. Meaning, it is not resting flush – there is quite a bit of play. But, there is no real way to make it seat better. It really is seated as much as possible, it just has some wiggle to it. So, when I go to move the fence, the fence/head unit wiggles which shoots the fence at least 1/8-1/4 of an inch in the direction you are pushing and thus out of square. I did not see a tightening screw to take out the play either. I am confused…. What in the world am I doing wrong?
Thanks for your help.
-- Jeremy, Kingwood, Texas
2 replies so far
View knotscott's profile
7936 posts in 3307 days
#1 posted 08-16-2012 09:04 AM
What happens if you partially engage the handle to take up the wiggle room?
View jlasersmith's profile
45 posts in 2083 days
#2 posted 08-16-2012 01:12 PM
That was going to be my suggestion. I thought I had the same problem… then I noticed that it only happened when I was holding the handle up while moving the fence.
Good luck,
-- I tell you, we are here on Earth to fart around, and don't let anybody tell you different. -Kurt Vonnegut
