Table saw blade for ripping thick oak lumber
Forum topic by brantley posted 08-16-2012 12:24 AM 7898 views 0 times favorited 5 replies Add to Favorites Watch
View brantley's profile
brantley
185 posts in 3377 days
08-16-2012 12:24 AM
Ive got a craftsman table saw that needs a new blade. If im wanting a blade strictly for ripping boards how many teeth should I look for. Home depot is my only option to buy from locally so if anybody has any reccomendations from there it would be appreciated. Thanks
5 replies so far
View knotscott's profile
knotscott
8122 posts in 3496 days
#1 posted 08-16-2012 12:54 AM
The Freud Diablo D1024X is a good 10” 24T 3/32” thin kerf blade that should be pretty efficient in thick oak, easy for your saw to spin, and will give a marginally clean edge that might be glueable directly from the saw if the wood is flat and straight and if the saw is aligned well. It’s about $27 at HD, and would be about the only choice from that store for your application that I’d consider….I’d avoid their Avanti/Avanti Pro, Workforce, Ryobi, Oldham contractor series, and the DeWalt Construction series.
View nwbusa's profile
nwbusa
1021 posts in 2406 days
#2 posted 08-16-2012 01:00 AM
Agree with knotscott. I use that very blade to rip 8/4 maple and it does a fine job.
-- John, BC, Canada
View _Steve's profile
_Steve
85 posts in 3147 days
#3 posted 08-16-2012 01:13 AM
I agree also, I just pick one of the D1024X up at HD and it does real good on 8/4 Red Oak. It does leave some saw marks, I would not use it as a glue line, IMHO.
-- McMaker Woodworks, Where you can give directive for a pending antique.
brantley
#4 posted 08-16-2012 01:19 AM
Knot I know the blade you are talking about .I have had my eye on it for a while. I am not real sure how to check and make alignment changes. The blade on it now was not make satisfactory straight rip cuts on the oak.
View oluf's profile
oluf
260 posts in 3159 days
#5 posted 08-16-2012 02:30 AM
For safety reasons I do not use the same kind of a blade for ripping rough sawn boards as I do for ripping boards that I have joined and planed. You need to rip out a wide kerf on rough and twisted lumber to prevent binding and kick-back.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
