Any use for Furnace Air Handlers?
Forum topic by Scott posted 08-15-2012 07:48 PM 2526 views 0 times favorited 10 replies Add to Favorites Watch
View Scott's profile
153 posts in 2904 days
08-15-2012 07:48 PM
We are about to replace both of our A/C’s and gas furnaces due to age and failure. The air handlers in each are still functioning so I was wondering if there is any value in stripping those out and using them for something else or even trying to sell them? I don’t have an immediate need but I hate to see them go to the landfill. And, if anyone in No. Va. is interested, let me know.
10 replies so far
View dbhost's profile
5687 posts in 3164 days
#1 posted 08-15-2012 08:02 PM
The Squirrel cage fans and motors can be reused to shop build ambient air cleaners for shop use…
-- My workshop blog can be found at, YouTube Channel
View jlasersmith's profile
45 posts in 2083 days
#2 posted 08-15-2012 08:06 PM
I recently came across a fan and a motor and was wondering what to do with it. I was thinking some sort of air cleaner or dust collector.
-- I tell you, we are here on Earth to fart around, and don't let anybody tell you different. -Kurt Vonnegut
View DannyJ's profile
23 posts in 2044 days
#3 posted 08-15-2012 08:23 PM
I’m in the process of building a sanding table that will include a furnace blower, see attached. It is also designed to function as a shop air cleaner, with space for 24×24x4 first stage filter and 24×24x6 HEPA filter.
I’ll let you know how it turns out.
-- Danny, Houston, TX
#4 posted 08-15-2012 09:54 PM
Thanks for inspiration. I’ll try to pull one or both while the guys are here Friday.
View waho6o9's profile
8130 posts in 2509 days
#5 posted 08-15-2012 10:24 PM
Care to make a sander with one of your motors?
View JesseTutt's profile
854 posts in 2042 days
#6 posted 08-17-2012 03:13 PM
I have vents on the side walls of my shop up by the peak of the roof. I put furnace blower fans in each. Now when it is cool outside i turn the fans on and they suck out the hot air and pull in cool air.
View OggieOglethorpe's profile
1276 posts in 2042 days
#7 posted 08-17-2012 03:16 PM
You could also use the surplus handler to ventilate a spray booth for non-flammable finishes.
View Dustmite97's profile
439 posts in 3152 days
#8 posted 08-21-2012 05:09 PM
I’ve been wanting to make an air cleaner with an air handler for a while now.
View Bernie's profile
422 posts in 2769 days
#9 posted 08-23-2012 02:37 AM
When sanding on the workbench, I place an ordinary box fan with a furnace filter taped over the intake side which faces my work area. When I’m done, I take it outside to tap the duct off of it. It’s not the best solution – but it works…
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View hairy's profile
2626 posts in 3464 days
#10 posted 08-23-2012 01:26 PM
Here’s what I did.
Put them on craigslist for $20, they should go quick.
-- My reality check bounced...
