| Forum topic by JK0702 | posted 275 days ago | 1308 views | 0 times favorited | 41 replies | ![]() |
275 days ago |
As I’m fairly new to this site, I have found the forum topics very interesting and enlightening. One of the most helpful was the “Acronym Glossary” posted recently. With that in mind, I thought it might be helpful/interesting to know what are the rules of woodworking, or rules of the shop that you employ. For example, there’s the obvious, “Measure twice, cut once”, but I’ve also picked up other gems such as: - Only one person pushes a board through the saw One that I’ve seen, but still don’t know the rule, is the thumb and finger rule for routing. Can anybody explain that one? So I’m interested to know your “Rules of the Shop” ... or simply your “Rules of Woodworking”, and any explanation or description that would help. Any takers? JK -- John - Huntington Beach CA |
41 replies so far
#1 posted 275 days ago |
Here is my #1 rule. The shop is not a storage area for the wife. She does not even have a key to it. |
#2 posted 275 days ago |
I live by this guys rules: -- ~Just A Guy With A Hammer~ |
#3 posted 275 days ago |
I have a couple actually… #1 (taught by my Dad to me when I was a kid) “Don’t ever fear the power tool, respect it for what it can do to you” #2 Mistakes happen. Fix them or deal with them and move on. #3 Even though you may have used the tool a thousand times, check your set-up again. I don’t know how many times I’ve overlooked something as small as tightening a collar on my laminate router only to figure it out as my new beautiful piece has an odd edge…in this cae refer to rule #2. -- Do or do not...there is no try - Master Yoda |
#4 posted 275 days ago |
I have several shop rules that I need to organize, get printed and post on the wall. #1. No you may not borrow my tools. #2. NEVER attempt to take my attention away from any task I am doing when operating any powered equipment, or anything with sharp edges such as chisels, planes etc… #3. The storage area allotted for lawn and garden is limited to that area, it is not to intrude into the shop area, or vise versa. #4. Smoking is absolutely forbidden in my shop. (for safety as well as health reasons). #5. Operation of any power equipment, or anything with a sharp edge shuch as chisels / planes etc… is forbidden once ANY alcohol is consumed. Simply put, the first drink brings shop time to an end. The phrase “hold my beer and watch this” doesn’t impress anyone other than the paramedics. #6. You want to come out and visit in the shop while I clean? Great! You want to help clean. No problem as long as you verify with me where things are supposed to go. Last thing I need to find is my taps in the drill bit index. #7. If the do not enter sign is on the man door, obey it. Sometimes quiet things need to be left alone, such as when finishing. I want the air to be as undisturbed as possible… #8. Please ask me if you want to do some sort of work in here. (usually painting craft projects or what not). That way I can prepare the space for you so that you don’t hurt yourself, of those things around you. Remember there are sharp, pointy, spinny things in here. #9. None shall enter my shop unaccompanied by me. There are things that can hurt you in there. Again, I can prepare things so that the sharp pointy world isn’t quite so harsh… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#5 posted 275 days ago |
I like all the suggestions so far, especially DBhost’s list. I agree that once the beer comes out, no more sharp objects or power tools….except the palm sander. I don’t know, something about sanding makes me wanna drink :) More of a saying than a rule but I also like “A clean shop is a safe shop” Crap on the floor or piled up on a bench or outfeed table can become a safety issue in the middle of a cut or operation. I also say “A place for everything, and everything in it’s place.” Yeah…I’m one of those guys, LOL -- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com" |
#6 posted 275 days ago |
Here are a few to add since my wife as recently taken to woodworking and joins me quite a bit: 1 – If I am wearing safety gear (respirator, eye/hearing protection) so are you. I don’t care where you are or what you are doing. 2 – If I am at the table saw or router table, you aren’t doing anything until I am done. You are also not standing in front of or behind me. 3 – Clean up your dust after each operation. I hate piles of saw dust (no proper dust collection yet) 4 – no sanding or cutting while finishing is in progress (applies to each of us) 5 – Don’t touch any settings on anything ever. I will set up the cuts ( cutter/blade height or angle, fences, jigs, featherboards, edge guides, etc). If you need something set up, ask. Also, do not make any cuts until I have set it up 6 – If I find a cutting impliment such as a saw blade, drill bit, router bit, chisel, etc out of place or tossed on a bench after use, it’s game over forever. I take very good care of my stuff in order to make sure it stays clean and sharp. If one of my 50+ dollar router bits rolls off the bench onto the concrete, I am going to be pissed. Alternately if you don’t tell me that happens and the carbide breaks up the next time I use it due to a stress fracture, I will be even more pissed |
#7 posted 275 days ago |
JK0702 : The thinking here, of course, is that you want to oppose the tendency of the router to “run along the wood” due to bit rotation. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#8 posted 275 days ago |
I have been routing for many years and I always rout counterclockwise. I presume this is right to left and I works just fine and gets the results I want. I guess it depends on if you are using a hand held router of a table mounted router (upside down opposed to right side up). -- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com |
#9 posted 275 days ago |
I’m trying to train my family that when I’ve got a tool running, IF they come out to visit or ask a random question, that they need to wait until I turn it off before trying to get my attention. So far it seems to be working. and I still have only the usual allotment of 10 digits, vs say, 9.5 or 11 -- Ned - 2B1ASK1 http://nedswoodshop.blogspot.com |
#10 posted 275 days ago |
I would like to speak to the router rule. Basically 1+ with what Montecristo said. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#11 posted 275 days ago |
MonteCristo & Pintodeluxe … thanks for the clarification on the router rule, it makes sense now. -- John - Huntington Beach CA |
#12 posted 275 days ago |
Yep, routing with (or in) the direction of the bit rotation is known as climb cutting and can be very dangerous if you don’t take special precautions. My shop rules are pretty simple. Don’t touch any of my stuff without asking me first. Aside from that, common sense usually prevails (even with a wife and three daughters who sometimes forget that my machines are not temporary counter tops, places to lean their bicycles against, etc….) -- John, BC, Canada |
#13 posted 275 days ago |
1. Don’t rush it…. if I’m in a hurry… time to stop. obtw…. I think climb cutting has a place…. but is best left to operations done on the router table. -- Matt, Pine is fine, but Oak's no joke! |
#14 posted 275 days ago |
I have a few simple rules: For others: For me: -- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain |
#15 posted 275 days ago |
Sight Distraction Pre-flight Checklist Eye & Ear Protection On? You don’t need it written down, but running through this list before each operation helps me ensure I’ve checked the critical boxes, and also gets me focused on the work at hand. Many times I thought I was ready, ran through this list and found one or two things I didn’t have solid in my mind. I know some of the old timers and pro’s will laugh at a list, but I did not grow up around power tools, and do not use them often enough to have it ingrained in me yet. In terms of router cutting direction, +1 to MonteCristo – the general goal is to avoid or carefully control the situations where you make a climb cut – ie feed wood in the direction that cutting is occurring. Normally, you will feed ‘against’ the cutting direction of the router bit. There are times when you will want/need to do climb cuts, but you need to understand the problems it poses and plan accordingly (use power feed or very solid work-holding techniques and jigs) or avoid it all together. Also, make sure to start a curved/fenceless flush trimming operation with the ‘pin’ in place to steady the work. Failure to do so can also ruin a piece and/or boxer shorts. Stay Safe, -- Chris @ Atlanta - JGM - Occam's razor tells us that when you hear hoofs, think horses not zebras. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15747 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
