How many coats of Oil based GF ArmRSeal for dinning table?
Forum topic by Stovall posted 277 days ago 695 views 0 times favorited 8 replies Add to Favorites Watch
View Stovall's profile
Stovall
6 posts in 279 days
277 days ago
I’m new to finishing, but I thought I’d have a go at my wife’s dinning room table. I’ve been unable to identify the wood, but have ruled out oak. I started with two coats of GF gel stain, and now am ready to apply my third coat of GF ArmRSeal. My question, how many coats will it take to get a finish that withstand a hot cup of coffee, or cold glass of ice tea, without marring the finish? Is this even possible? Any advice would be great. Also, should I buff out with wax, if so, what kind. Thanks for a great forum….
8 replies so far
View CharlesNeil's profile
CharlesNeil
855 posts in 2037 days
#1 posted 277 days ago
the key to arm r seal or any finish is to get enough to look good, thats enough, contrary to poplar belief more isnt always better, typically 3 good wet coats will do, if your wiping on and off, thats a very thin coat, so maybe 5 , again, looks good is good, but 3 is a min for me, brushing, 5 if wiping, No finish will like hot coffee, of any single thing that will cloud and ruin a finish , heat is number one, ice cold drink, no issue, just watch the coffee,
View lumberjoe's profile
lumberjoe
2396 posts in 415 days
#2 posted 277 days ago
hey Stovall,
If I read correctly, you’ve already applied 3 coats of Arm-R-Seal? That should be plenty for protection, I would just be concerned with the quality of the finish. I would sand with really light sandpaper (800 grit +) or use some 0000 steel wool then put one more finish coat down. After that dries for at least 48 hours, ideally 72 hours gently buff it out with furniture paste wax applied with steel wool. Stay away from automotive and silicone based waxes. You can find good old Johnson’s everywhere, and that stuff is like gold to have around the shop anyway. Minwax also makes a finishing paste wax that is readily available almost everywhere as well. Once the wax hazes over, buff out with a thick lambswool pad. I usually wait a few hours and apply another coat. If there are still nibs/imperfections in the finish I use steel wool again. If not, the wax goes on with cheesecloth. Don’t build up a lot of wax though if it will get hot/wet.
-- http://www.etsy.com/shop/KandJWoodCrafts
View Earlextech's profile
Earlextech
591 posts in 857 days
#3 posted 277 days ago
Three to four coats should be sufficient depending on the thickness/plastic look you are happy with. And I would absolutely finish it out with paste wax, let the finish cure for a week before waxing. Two coats of wax initially, I always wax anything that will be touched by skin on a regular basis.
-- Sam Hamory - The project is never finished until its "finished"!
Stovall
6 posts in 279 days
#4 posted 276 days ago
Thanks, guys, for the great advice. I have wiped on two coats so far, so I’ll give it another three lite coats, then apply the wax. I look forward to being a member of LumberJocks, what a great resource.
CharlesNeil
#5 posted 276 days ago
I agree , no wax for at least a week or 10 days, other wise you can slow the cure of the finish, also often wax will streak on a new finish, this is becasue it still has some solvent in it, and it softens the wax, check out your local auto body store and get some finishers glaze also called swirl remover, its a wax of sorts, but is designed to be used with new finishes, but you dont need anything, also when its good and dry to help the feel buff it a little with a brown paper bag, helps give a buttery feel
lumberjoe
#6 posted 276 days ago
Charles, to remove swirls, I often use a product called PerfectIT II from 3M. I also use it to buff out automotive finishes after wet sanding. It’s a 3000 grit buffing compound. I have had OK results using it, but it is silicone based and I often wondered if it contaminates the finish, or will develop the “fish eye effect” that silicone based products have over time. Is there something specifically you would recommend?
Also your Pre-Color Conditioner is probably the best finishing related product I have ever used.
Stovall
6 posts in 279 days
#7 posted 276 days ago
More good advice, I understand now, how the curing process works,’and why it’s important to wait before applying wax. Knowing why something is helps me grasp the concept. Thanks guys…
Earlextech
#8 posted 276 days ago
I’ve buffed with brown paper bags for almost 30 years, it’s just one aspect of a “hand rubbed” finish, which I do with a spray gun.
