Changing my jointer blades
Forum topic by Monty Queen posted 279 days ago 908 views 0 times favorited 16 replies Add to Favorites Watch
View Monty Queen's profile
Monty Queen
1568 posts in 1420 days
279 days ago
Topic tags/keywords: question
Hey Lumber jocks, I change my jointer blades this weekend. It was lot harder then it looked on the internet. I watched and read several articles about changing blades. I have a ridgid jointer i bought for home depot. I had a few nicks in my blades from runing boards in my jointer with small nails in it. It bothered me seeing those nicks so i changed the blades. The way i did it was used magnets with finding the center. I must of changed them blades 20 times trying to get it perfect. Some how i am still getting a little snipe. After playing with it for hours. I decided a little snipe will not hurt if i join boards to gether i will cut the inch of snipe off my board. I have read a lot of articles about changing blades and they said when you get a snipe your outfeed table is two high. I would like to get comment from all of you.
Thanks
Monty
-- Monty Q, Columbia, South Carolina.
16 replies so far
View thedude50's profile
thedude50
3316 posts in 646 days
#1 posted 279 days ago
Yes when you set your blade height you are supposed to be on plane with your out feed table. I don’t know why you would have to change them 20 times unless the jointer has a lame setup for adjusting the blades. I can auto-set my knives on the Powermatic 54a and they are easy to adjust should the auto-set not be dead on but it has always been dead on, so I don’t mess with it. It has always been set and go.I set my friends jet up a couple of weeks ago and it had a two screws to adjust the irons they were easy to get set with a straight edge. You can also use a dial indicator to find zero. The whole process should be able to be done in 10-15 minutes. I am really sorry you had such a hard time was this your first blade change ?
First Some simple things that might help you would be do you have a steel straight edge like a machinist uses ?
if not get one it will help you a great deal.
SECOND do you have a dial indicator? if not invest in one you will use it for lots of machine setups .
Third Read your Manuel very carefully and make sure you knife is level with your out-feed table on both ends of the knife. it they are tilting you will struggle for days.
I have heard good things about the jointer you have so I will assume this is all new to you. If you have more questions PM me I can be reached by telephone most days and would be happy to talk you through the set up. If you can, send me a copy of the owners Manuel in a PDF format. I am used to helping people with machines I have not worked on before because most of them work the same way.
-- when I am not on Lumberjocks I am on @ http://thisoldworkshop.com where we allow free speech
View Rick L's profile
Rick L
512 posts in 1929 days
#2 posted 279 days ago
Snipe is from having your outfeed table lower than the height of the knife. Having the outfeed table higher causes tapers and by the time you get to the end of the board you not be cuttin wood. Outfeed table just a few thousandths will cause this. Outfeed table 1/32” high will stop the board dead in it’s travel.
Been repairing and adjusting machines in commercial shops for 30 years now…
-- Few folks really know how to maximize the potential of their tools!
View b2rtch's profile
b2rtch
2954 posts in 1217 days
#3 posted 279 days ago
My opinion is that replacing blades is not as hard as it is time consuming and a real pain the a**. This is not rocket science.
This is why rebuilding this 38 years old Powermatic 60 , in-spite of the cost, I choose to buy a Shelix head.
Eat a nail= loose a cap-screw, rotate the cutter 1/4 turn ,you are done. No adjustment to mess with.
In addition the cutter cost only $3.00 each or 75 cents/edge. Very inexpensive to use after the initial cost.
-- Bert
View Oldtool's profile
Oldtool
940 posts in 359 days
#4 posted 279 days ago
Qmoney,
I have the Delta 13” portable planer, but that shouldn’t make a difference here with how I avoid tail end snipe:
When the board is coming out of the planer, I put my hand under the leading edge, and lift up ever so slightly, especially at the end of the run so the board doesn’t sag. This has been pretty successful for me, might give it a try.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View Jim Jakosh's profile
Jim Jakosh
7264 posts in 1274 days
#5 posted 279 days ago
Hi Monty. I sounds like an outfeed table adjustment. I have a Grizzly and the way I do it is to lower the outfeed table out of the way a bit, then feed a board through about 2”. I shut off the machine and back the board up a bit to clear the cutter head and then carefully raise that outfeed table until it just kisses that cut edge. You can slide the board back and forth to make sure there is no catch and there is no gap.
The knife has to be parallel with the outfeed table to begin with. That is where an indicator is helpful to check each end to make sure they are the same height with respect to the table. Sounds like you have that set pretty good.
I think the snipe is coming from table height! I’ve had it and adjusted out of it like I stated above.
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
View mtenterprises's profile
mtenterprises
623 posts in 861 days
#6 posted 279 days ago
I set my knives with a magnet too. The only thing I found that was a problem was making absolutely sure the the knife being set was exactly vertical on the flat cutting edge. If it’s not then it will make a deeper cut. See picture below. (We need an on line chalkboard).
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View ssnvet's profile
ssnvet
1552 posts in 497 days
#7 posted 279 days ago
Q,
Setting jointer knives certainly can be a pain…. but you get better at it with practice. BUT… knife height is not the only source of snipe. You can also get it if the infeed table is not paralell to the out feed table. And the only way you can really evaluate this is if you invest into a very precise straight edge and a set of feeler gages.
This link shows the most affordable straight edge I’ve found is at Lee Valley....
unfortunately, on most jointers with dovetailed ways…. there are not many options to correct an out of parallel table. You can adjust pressure on the gib lock, or clean up the dovetail ways and adjust the gibs, or shim the gibs (which I’ve never had to try, but looks like a very frustrating, trial and error job in itself).
My next jointer will be a parallelogram machine, because the table parallelism is adjustable.
Hey Bert….
Glad to see the jointer re-hab is coming along….just a heads up wrt. indexable/replaceable carbide cutters….. Don’t be surprised if when you chip a cutter, it is most often at the corner (where they are the weekest) and thus you lose two edges, and have to rotate 180 deg.
Still a great system…. the cat’s meow in my book…. but our experience at work is that they always get rotated 180 deg. and give you two perfect cutting edges (not four).
-- Matt, Pine is fine, but Oak's no joke!
View TheDane's profile
TheDane
2676 posts in 1831 days
#8 posted 279 days ago
I have the Jointer Pal (Grizzly Part No G3360) ... makes setting the knives a breeze.
—Gerry
b2rtch
#9 posted 279 days ago
ssnvet, good point
-- Bert
View woodenwarrior's profile
woodenwarrior
13 posts in 363 days
#10 posted 279 days ago
To be honest, if you are getting snipe at the end of your board with a jointer it has very little to do with your knives and everything to do with how you are feeding the lumber. Make sure that when you are feeding the lumber over the jointer you allow the first 8-10 inches or so to pass over the knives then place your first hand/hold down over the out feed side. Continue to push the board from the infeed side but make sure that your downward pressure is being focused on the outfeed not infeed side.
-- Do or do not...there is no try - Master Yoda
Monty Queen
#11 posted 279 days ago
Thanks guys for all of your advice, I played with it again this morning and it looks real good now that i have taking your advice.
Thanks Monty
View ScottStewart's profile
ScottStewart
57 posts in 300 days
#12 posted 279 days ago
I also got snipe if my blades were higher than my outfeed table. There is one video out there by a guy I respect that says to set the blades 1-2 thou higher than the outfeed. I got snipe doing that. Readjusting the outfeed fixed my problem.
Scott
View crashn's profile
crashn
507 posts in 634 days
#13 posted 279 days ago
I also tried just last weekend to change my jointer blades for the first time. My jointerpal (from rockler) helped. I did make one mistake and had one set screw a bit loose and the blade shifted up, causing SEVERE snipe at the end. When inspecting the head, i noticed the one blade was off ALOT. after fixing that and verifying that the blades were level with the out-feed, snipe disappeared.
I was very anxious doing this, it was my first time and I had been in the need for a while. It did take a while (couple of hours in my case), but I am sure I will get better/faster with it. Now, I’m not afraid to change them. Still want a spiral cutter-head, but that will have to wait until I get the Grizzly Jointer/Planer 12” combo with spiral cutte-rhead. Hope to this September, during their Muncy PA tent sale!
-- Crashn - the only thing I make more of than sawdust is mistakes
Rick L
#14 posted 278 days ago
Wooden warrior…snipe is all about knife setting not about technique…Period! Spend the next 30 years doing this for a living and say that with straight face…
thedude50
#15 posted 278 days ago
I have to agree with Rick on this it has zero to do with how you feed the board its all about the set up. I am very happy that this user was able to get his out feed table level with his knives and put an end to the snipe. I am curious Rick since you do this every day for a living does that mean your at one shop fixing other peoples jointers or do you travel from shop to shop to do this type of set up? I am also curious how you set up the jointers. I have used the straight edge to set up a jointer since I learned many years ago. I never have any problems with machines I set up and am thinking of doing this type of work part time. I think there is a market for this in this city. I have never needed a magnet to set up a jointer or a jointer buddy. I am curious what you use when you do this on a daily basis. Thanks for the reply Rick I think if you do it daily your an expert.
