What is the best way to fix this?
Forum topic by WoodHoarder posted 08-15-2012 03:13 AM 1093 views 0 times favorited 5 replies Add to Favorites Watch
View WoodHoarder's profile
WoodHoarder
67 posts in 2278 days
08-15-2012 03:13 AM
Topic tags/keywords: question
I’m hoping to pull upon the wisdom of more experienced lumberjocks in this this regard. The project is a pair of exterior french doors. The joints are drawbore joints. I’m no stranger to mortise and tenon joints, but I felt i needed the added strength by adding pins.
So, I drilled the holes in the mortises and drilled the tenons with a 1/32 offset. I added a chamfer to the dowels. When it came time for assembly I gave the dowels a good whack with my hammer and the above picture is the result. My wife came running out probably thinking I had cut my finger off with the amount of cursing.
The nicely seasoned cedar had blown out the back. Well, lesson learned. On the other joints, I sharpened the dowels to a nice point and gently tapped them in.
Still, I am stuck dealing with the blowout. The door is going to be painted and will be exposed to direct sunlight. It is southern CA so the weather is not particularly extreme. The joint itself turned out to be very solid despite the blowout. I have considered filling it with tight bond III and sanding it flush, or gluing the broken pieces back in.
Any suggestions would be greatly appreciated.
Thanks
-- Christ was a carpenter...a fact that humbles and inspires me.
5 replies so far
16274 posts in 4215 days
#1 posted 08-15-2012 03:20 AM
Auto body filler (Bondo) will fill things like that nicely. Leave it a little proud of the surface, and sand flat when dry.
View Richard's profile
Richard
400 posts in 2688 days
#2 posted 08-15-2012 03:43 AM
Charlie is right, bondo is the way to go if it’s going to be painted. I fixed a rusty set of hand rails that way once. After sanding and paint you could not tell where the repair had been made.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
117091 posts in 3574 days
#3 posted 08-15-2012 03:55 AM
It’s a little hard to see in the photo.Bondo will work or you can cut it flush and drill about 1/8” deep and put an inlay in it chiseled square or drilled round. This would be great inlay practice. If you screw it up there’s always bondo to fall back on.
WoodHoarder
#4 posted 08-16-2012 08:46 PM
Thanks for the advice. You guys are awesome!
View Ger21's profile
Ger21
1074 posts in 3128 days
#5 posted 08-17-2012 02:14 AM
I wouldn’t use bondo, as over time it will loosen from wood movement. I’d use epoxy with a sandable filler. It won’t ever come loose.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
