| Forum topic by fonzie | posted 281 days ago | 528 views | 0 times favorited | 3 replies | ![]() |
281 days ago |
Topic tags/keywords: flatten true plane joint pallet question milling joining Hi there, This weekend I’m planning on cleaning up some pallet wood to be used for a bench and table. The only bench planes I have are a number 3, 4 and 5. I’ve also got a chop saw and a random orbital sander. How would you all suggest I flatten and true this stock for use? Should I add a scrub plane or a longer jointer like a #7 or 8? Thanks, Jay |
3 replies so far
#1 posted 281 days ago |
I think you should be able to get the stock face jointed flat enough for your projects with the current planes in your arsenal. If you plan on using the planes to edge joint the boards as well, then it depends on how long your joints will be. A number 5 should be adequate for edge jointing up to a couple feet, but much beyond that and I would look for a #7. A #8 would be better in theory, but that size is too unruly for me. Good luck with your project. You are an ambitious man! -- PaulMayer, http://www.vernswoodgoods.com |
#2 posted 281 days ago |
If you work with pallets, you might want a metal detector. I have this one: http://www.woodcraft.com/product/2003820/9451/little-wizard-ii-metal-detector.aspx Or , you can do like I did and find nails with your jointer. -- It must be jelly baby, cause jam don't shake like that... |
#3 posted 281 days ago |
Thanks for the replies. Paul, I am planning on edge jointing the boards (about 4’ long) for a table top, so I will go ahead and look into a #7. hairy, good call on the metal detector. Hope your jointer is doing alright… Any suggestions on sealing this well to prevent any chemicals that may have spilled onto the pallets from leaching out? |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3551 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6160 |
