Delta rockwell saw, what can you tell me about this?
Forum topic by jlasersmith posted 281 days ago 381 views 0 times favorited 1 reply Add to Favorites Watch
View jlasersmith's profile
jlasersmith
42 posts in 322 days
281 days ago
Topic tags/keywords: delta rockwell table saw
I am thinking about buying this saw. The guy didn’t give me the model #. Here are some pics. Anyone know what model this is? All I know is its a 1hp.
-- I tell you, we are here on Earth to fart around, and don't let anybody tell you different. -Kurt Vonnegut
1 reply so far
View toolie's profile
toolie
1110 posts in 799 days
#1 posted 281 days ago
right tilt probably 10” CI contractor TS with a crummy fence. fairly typical item worth between $50 and $100. does it come with extension wings and are they CI or stamped steel? the motor is dual voltage (115/220) and under the cover that has that data plate should be a wiring diagram that will have information about how to switch the voltage. it DOESN’T develop more power if wired for 220v. beinig partial to left tilt saws, i;d pass on it.
