flattening a wooden try plane
« back to Hand Tools forum
Forum topic by 12strings posted 08-14-2012 02:07 PM 1278 views 0 times favorited 5 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2289 days
08-14-2012 02:07 PM
What are my options for truing up the sole of an old wooden Try Plane? It is 22” long. I do not have a power jointer or a Longer jointer plane. I do have a No. 5 jack plane. Can I clamp the woodie in a vise and use the jack to flatten it…or would sandpaper on granite be better?
thanks!
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
5 replies so far
View Deycart's profile
Deycart
444 posts in 2162 days
#1 posted 08-14-2012 06:39 PM
If you have the granite I would go that way. Especially considering that it is a woodie and would go really fast. I have had success using the top of my table saw and some sandpaper to smooth out some wood planes.
View whitewulf's profile
whitewulf
452 posts in 2842 days
#2 posted 08-14-2012 08:15 PM
If concerned with making the mouth to wide, consider thicker blade, or add insert before flattening.
-- "ButI'mMuchBetterNow"
View Don W's profile
Don W
18604 posts in 2472 days
#3 posted 08-14-2012 09:23 PM
I agree the jack will probably make it worse. sandpaper on granite would be better in my opinion to.
View Loren's profile
9948 posts in 3553 days
#4 posted 08-14-2012 10:58 PM
Get a 6” wide x 48” belt sander belt and cut it. You can
glue it to anything flat. A piece of granite works but a
flat piece of MDF or melamine will do. 1.5 belts makes you
a 24”x18” sanding board, which is more useful than you’d
think for woodworking. Aside from truing wooden planes
you can flatten box rims in a jiffy with it. They are useful
for building acoustic guitars, which is how I picked up the
habit.
whitewulf
#5 posted 08-16-2012 11:09 PM
Do not forget, to install iron & wedge, while flattening to maintain proper torque.
