| Forum topic by Chris | posted 76 days ago | 340 views | 0 times favorited | 22 replies | ![]() |
76 days ago |
I am trying to visualize a desk design for my own office and cannot seem to get Sketchup to do what I want…. Let me go through what I have done step by step 1. Basic Desk Top – 24”x50” at center of radius 2. Proposed shape of the edges 3. First Try – Drew the arc on each end; the arc started at the top corner with the second point 1/2” in from the lower corner. Then I completed the circuit by drawing a line across the bottom connect both 1/2” end points and erasing the result. 3a. Looks Good, eh? 4. Second Try – Using the Offset Tool I created the secondary shape offset from the original by 1/2”. 5. Second Try – Erased the edges…. 6. Utter & Dismal Failure – Help!!!!! I’m Lost!!!!!!!!!!!!! Can any of you experts out there offer any suggestion? Basically the edge treatment would be what resulted from using a larger diameter round-over bit on the edge…. I will be constructing the final design from two very large Padauk slabs I acquired the end of last year. One is 6/4×21” x 17’ (thats right feet!) and the other is 6/4×19” x 18’. UPDATE: So, I tried Gizmodynes solution and ended up with the following: 3rd Try – View of the end bevel; Whats with the leftover bits???? 3rd Try – View down the side Result after cleanup…. Looking good! This view is from the bottom…. Final: Applied wood grain texture to get a feel for what the finished desktop might look like. Final Questions: Thanks for all you help Gizmodyne & Greg Wurst! -- Chris |
