Evapo rust - how I ruined my Tablesaw.
Forum topic by david_larch posted 08-14-2012 02:23 AM 9435 views 0 times favorited 13 replies Add to Favorites Watch
View david_larch's profile
david_larch
102 posts in 2270 days
08-14-2012 02:23 AM
Having seen the great reviews on here for Evapo Rust I thought I’d give it a try. First time I followed the manufacturers instructions and had a complete green and black mess. Second try I used old tee shirt material and covered it, checking in on the progress. Much like the first try my saw is almost completely black. Im so mad I could throw my saw in the street.
-- www.alibiwoodworks.com
13 replies so far
MrUnix
6597 posts in 2166 days
#1 posted 08-14-2012 02:30 AM
Evapo-rust is fantastic stuff.. I use it on everything rusty and have gone through gallons of the stuff with 110% complete satisfaction. Maybe if you could give a little more information other than “green and black mess” myself and others could get an idea of what exactly you are talking about!
View ShaneA's profile
ShaneA
6910 posts in 2566 days
#2 posted 08-14-2012 02:39 AM
Got some pics? Maybe there is a simple solution.
View Arlin Eastman's profile
Arlin Eastman
4179 posts in 2529 days
#3 posted 08-14-2012 02:43 AM
You have to have the object completly under the solution.
Arlin
-- Please help me help other Vets click..> http://www.gofundme.com/m1abko.....It is always the right time, to do the right thing.
View Deycart's profile
Deycart
444 posts in 2225 days
#4 posted 08-14-2012 02:49 AM
You normally submerge what your working on. If you cant do that you could build a damn with some tape around the top.. I assume you want the top done and just flood it. As far as the black “stuff” that is the oxide that you can just scrape off. Don’t sand just use a plastic putty knife to take it off. Then build the damn and use what you got left.
View Mainiac Matt 's profile
Mainiac Matt
7948 posts in 2296 days
#5 posted 08-14-2012 02:55 AM
Don’t fret….. It will come off….. As already said, it has to soak.
I put each wing one at a time in a jumbo storage tub filled about two inches deep. The were soaked upside down, blocked up from the bottom on small dice so only th to surface was submerged.
The Maine section of the top I did the same way in a kiddie pool.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
View Dark_Lightning's profile
Dark_Lightning
3146 posts in 3076 days
#6 posted 08-14-2012 02:57 AM
You can also just keep spreading the Evapo-Rust with a brush. You will eventually be done. I did my old cast iron table saw that way. It’s a waste of the solution, as I have learned. Submersion is the best. Difficult, at best, with a cast iron table saw.
-- Random Orbital Nailer
View dbhost's profile
dbhost
5705 posts in 3199 days
#7 posted 08-14-2012 03:07 AM
Evaporust is great stuff if you use it right…
MrUnix
#8 posted 08-14-2012 03:08 AM
Hmmm… if you are talking about the darker colored carbon film that is left on the surface with some metals, it’s easily removed. Even the evapo-rust FAQ has a blurb about it:
Q) I get a black film on some parts after using EVAPO-RUST™. What is it and how do I remove it?
A) The black is carbon from the steel. Generally high carbon steel is used in making items that are flexible (e.g. springs, saw blades) High carbon steel and tool alloy steel items when de-rusted will have a darker appearance. Much of the carbon can be removed simply by wiping with a cloth.
As for full submersion.. they used to say that was the only way to effectively get it to work, but after several people pointed out alternative ways, they also added the ‘moist cloth’ method. Continuous brushing also has been known to work, but nothing is as good as fully submersing it into the solution. For large flat surfaces, making a ‘dam’ like Deycart suggested works, or you can turn the part upside down and use a shallow container, like this:
View MedicKen's profile
MedicKen
1612 posts in 3430 days
#9 posted 08-14-2012 03:48 AM
Use a scothbright pad with a little WD40 as a lubricant and the black coating will come off. As the rust is converted it will turn black. The same thing happens with electrolysis. I use a knotted wire wheel onan angle grinder to clean the surfaces after rust removal. Dont fret it. It’s OK
View usnret's profile
usnret
184 posts in 2476 days
#10 posted 08-14-2012 04:25 AM
The black stuff is magnetite. It is actually good rust that protects from the bad red rust. Just use a scotch brite pad or sand paper and WD-40 to remove it.
-- Chief Petty Officer USN(RET) 1991-2011
View MonteCristo's profile
MonteCristo
2099 posts in 2156 days
#11 posted 08-14-2012 05:36 PM
I think I would focus more on how good a saw top you actually have than how pretty it looks . . . ie how flat is it, how slick is it . . . As for rust, keep the humidity level down with a dehumifier or some other method and rust won’t be an issue. If you have enough humidity for rust, it’s also going at your motor’s innards and other stuff that you don’t want trashed.
View MrRon's profile
MrRon
4719 posts in 3211 days
#12 posted 08-14-2012 09:46 PM
Sounds like a heck of a lot of work. How often do you have to repeat the process? I keep my machines rust free just with a good carnuba wax, applied once a month. The tops don’t shine like a mirror (who needs). It’s a tool to be used, not stared at loveingly. I remember my first new car (many years ago). I spent my weekends washing, waxing and polishing it and keeping it safe from the elements. A few months after I got it, I got into my first crash. I was sickened and I never worried about a car’s appearance ever again. A scuffy pad and WD-40 removes rust spots quickly and easily before waxing. Life is too short to worry about such trivial matters. Make sawdust and enjoy.
MrUnix
#13 posted 08-14-2012 10:48 PM
LOL – yup, it can be a bit of work, but you only need to do it once.. a scotch brite pad and WD-40 is going to be a LOT more work when you are starting out with something like this:
And want it to wind up looking something like this:
After that, you can maintain it with proper care and waxing.. but you gotta start with something solid, and evapo-rust makes getting rid of the years of rust and abuse fairly painless and much safer than many alternative methods.
