Help
Forum topic by IndianJoe posted 281 days ago 352 views 0 times favorited 9 replies Add to Favorites Watch
View IndianJoe's profile
IndianJoe
386 posts in 418 days
281 days ago
Topic tags/keywords: question
My wife got me a Black & Decker 41/2 Small Angle Grinder she thanks 5 years ago it was hide till the other day when she found it ,thank god I need it .
BUT when I tryed to use it it lasted all of 5 minutes.
I have had bad luck with this company be for but 5 Minutes takes the cake .
I call the company and they told me there nothing that can be done seeing that she did not have the sales slip . Ok it run good the grander will not turn what can I make with it ? Help
-- Nimkee** Joe
9 replies so far
View Monte Pittman's profile
Monte Pittman
7064 posts in 506 days
#1 posted 281 days ago
I have a black & Decker I use extensively. No problem. Could be the mechanical lock that holds the shaft still while changing attachments. Maybe it’s stuck.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View Jamie Speirs's profile
Jamie Speirs
3674 posts in 1025 days
#2 posted 281 days ago
As Monte says
Also if it has been sitting round it
have gathered some dust or splinter
in the slide switch, that happens a lot
with Trend Router switches
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View SteviePete's profile
SteviePete
207 posts in 1471 days
#3 posted 281 days ago
I have jammed the switch, burned the brushes,—Take apart the switch, check brushes rough’m up, polish armature with ink eraser—blow out crumbs. Put back together. Think positive – it will work, it will work, It will work. If not Mark $8.50 for rummage sale. It really should work. Even though we disrespect B&D I’ve gotten good enough service to pass them on to my daughters (still works for them, Too.) Good luck. s
-- Steve, 'Sconie Great White North
IndianJoe
#4 posted 281 days ago
It runs but the gears are gone what can I make with it ?
-- Nimkee** Joe
View MonteCristo's profile
MonteCristo
2060 posts in 357 days
#5 posted 280 days ago
Maybe you can take it to a small appliance repair place that services Black and Decker and see if they can at least shed light on what the heck is wrong. Hard to believe even with B&D that it would only last 5 min so maybe it’s not too serious.
View derosa's profile
derosa
1471 posts in 1004 days
#6 posted 280 days ago
You can make a dunk with it into the garbage. My B&D sander just spit out a bunch of stuff after only 3 uses, turns out it’s defective but they won’t fix it. They send you some parts so that you can do the job they couldn’t. Junk it, don’t tell the wife since she tried and get something better.
-- --Rev. Russ in NY-- A posse ad esse
View OnlyJustME's profile
OnlyJustME
1346 posts in 545 days
#7 posted 280 days ago
It would make a good paper weight, a noise maker, you could swing it around by it’s cord and bash stuff, or strip it for parts (at least the cord). the motor still works so maybe you could gear it down and connect it to a mobile or some other form of mechanical art with wood gears or something.
-- In the end, when your life flashes before your eyes, will you like what you see?
IndianJoe
#8 posted 280 days ago
Lol
-- Nimkee** Joe
View oldnovice's profile
oldnovice
1750 posts in 1536 days
#9 posted 280 days ago
I have never liked B&D but not for the reasons mentioned above.
My main reason for dislikng B&D is the extremely poorly designed batteries and chargers which, shouldn’t, but end up in our landfills due to customer dissatisfaction. In most cases the batteries cost nearly as much as the product and are difficult to replace. The only good B&D tool IMO, is the workmate.
And, also some STUPID products; the battery operated tape measure, the battery operated C clamp, the battery operated crescent wrench, maybe more I don’t know about.
Perhaps being part of Stanley will change this!
