Picked up a Rockwell 34-440 table saw
Forum topic by Jason posted 08-12-2012 11:21 PM 13758 views 0 times favorited 20 replies Add to Favorites Watch
View Jason's profile
Jason
8 posts in 2137 days
08-12-2012 11:21 PM
Found it on CL for $80 and had to have a look. No blade wobble, no movement in the shaft, just a smooth operator, except for start-up and shutdown. I put it to use yesterday and ripped some 7/16” OSB to finish a laminated beam for my horse shelter. It seems to lack enough power to rip efficiently. Upon further inspection, it appears to have “pot metal” pulleys and they’re definitely not true. This causes vibrations and probably reduced power transfer from the motor to the shaft. The motor is a replacement 1.5hp, 3,450rpm Dayton Industrial Motor.
Is the aforementioned motor OEM spec?
Is this the best deal for machined pulleys and link belt?
Should I toss in a couple of new 6203 RS bearings while I’m at it?
Where can I find a service manual for this saw?
Thanks,
Jason
20 replies so far
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2529 days
#1 posted 08-12-2012 11:46 PM
posting pics would better help the braintrust here help you.
congrats!
Beginningwoodworker
13345 posts in 3696 days
#2 posted 08-12-2012 11:48 PM
Congrats, I would love to see pictures.
RibsBrisket4me
#3 posted 08-12-2012 11:48 PM
Also try using a thin kerf blade. It can make a big difference on the “power” issue.
View knotscott's profile
knotscott
8055 posts in 3399 days
#4 posted 08-13-2012 01:07 AM
The first thing I’d do is to align the blade as close to parallel with the fence as possible, and would install a 24T thin kerf ripping blade like the Diablo D1024X for $27.
Jason
#5 posted 08-13-2012 02:35 AM
I’ll take some pics and post them when I get home from work tomorrow.
I ensured the fence was straight with a square at both ends before ripping that OSB. I took measurements at the front and rear of the blade and I did not notice it was off, not even 1/32”, but I will recheck. I’m not even sure how to align the blade – this is my first table saw. Is this an adjustment at the arbor under the table?
The saw had a thin kerf Diablo on it, but the PO kept the blade.
View MedicKen's profile
MedicKen
1615 posts in 3485 days
#6 posted 08-13-2012 12:00 PM
If the pulleys are pot metal they are probably original. you can replace them with machined steel but I would not use the link belt. The belt is a POS, that is unless you like vibration. My feeling on the belts is they are good as a back up and in an emergency until you can find a good v-belt. I am not familiar with the 34-440, but I am assuming it is a contractors style saw, so the 3450 Dayton is probably a suitable replacement. If you had trouble cutting OSB, I would look at the blade first, rip fence being parallel to the miter slots next. As for the bearings, replace them with the same number that is currently there. I would NOT use a generic bearing.
Jason
#7 posted 08-13-2012 12:32 PM
MedicKen, it’s a Rockwell Model 10 Contractor’s Saw 34-440.
Parts list.
The Delta bearing 1086894, which is the P/N for the bearings in the Rockwell 34-440, appears to be a 6203 RS bearing. No need to pay 4X the cost of a sealed 6203 RS because it’s in a Delta baggie.
I thought the link belt was supposed to eliminate vibrations, not cause them?
View Bluepine38's profile
Bluepine38
3379 posts in 3108 days
#8 posted 08-13-2012 02:19 PM
The original Delta bearing had a inner race that extended on one side and was slightly recessed on the other,
the 6203 will usually line up close enough not to cause any problems with your arbor alignment. On the
original electric motor, you would usually find an identical bearing being used.
View IrreverentJack's profile
IrreverentJack
727 posts in 2866 days
#9 posted 08-13-2012 05:32 PM
Jason, Here’s a link to a PDF manual for your saw from VintageMachinery.org . I bought pulleys and a PALs kit from In-Line and I liked both. You might be able to get the green link-belt at Harbor Freight. I have the red link belt and I like it. Can’t see how it would cause vibrations. -Jack
Jason
#10 posted 08-14-2012 03:12 AM
Well, the shop is a mess right now, but I took a few pics…
View cabmaker's profile
cabmaker
1735 posts in 2832 days
#11 posted 08-14-2012 03:24 AM
You got a deal on that one. Made lots of money using one like that. It will stack up well against anything out there for less than 600 bucks new !
MedicKen
#12 posted 08-14-2012 03:45 AM
The model 10 is probably one of the best made contractors saws ever made. There are a lot of them out there and parts are still readily available, not all through Delta but on owwm.
The link belts in my experince have actually increased vibration and slippage. If you look at the way the links are made they are FLAT, not in a V-shape. Therefore they do not fir into the pulley as a V belt would. Under power they tend to slip. But that is my experience only and I have heard of others with the same issues.
The 6203 bearings are readily available at just about any bearing house. I use Accurate Bearing exclusively. Their prices are the best I have found and always have what I am looking for.
knotscott
#13 posted 08-14-2012 10:59 AM
You sure got your $80 worth! Looks to be in pretty nice shape. Nice solid saw. For the price you paid, you could add a Delta T2 fence for $158 shipped, sell the original for ~ $50, and still have a really nice deal on a very slick setup.
Nice car too!
Jason
#14 posted 08-14-2012 12:20 PM
IrreverentJack, thanks for the parts list diagram. Are there actual manuals which show the actual adjustments made to the saw and maintenance? Are there any specific torque values when tightening things down?
Thanks all, sounds good. Is that the correct replacement motor? I just noticed it has 6203 bearings in it.
I tried to get a good picture of it, but the belt sits a lot lower in the smaller pulley on the arbor when compared to the pulley on the motor.
View dhazelton's profile
dhazelton
2771 posts in 2320 days
#15 posted 08-14-2012 12:42 PM
The correct replacement motor would be anything that spins at 3400 rpm and fits. Seriously, Dayton’s are good motors.
That saw is way too new to have a ‘pot metal’ pulley. I’d look to the arbor bearings or the belt for the vibration. $80 for a newer metal bodied saw on a stand with tables, fence and Dayton motor is almost as good as finding it with a FREE sign on it.
