Kerfmaker gone awry
Forum topic by Dan Corbin posted 278 days ago 613 views 0 times favorited 2 replies Add to Favorites Watch
View Dan Corbin's profile
Dan Corbin
32 posts in 327 days
278 days ago
Topic tags/keywords: jig question tablesaw kerfmaker
Hi all.
I was playing around with my new kerfmaker this evening and was having trouble making it work right (the dado cuts came out consistently too small). Now, the function of the tool is nearly idiot-proof, so I suspect that the cheap portable table saw I’m borrowing is the culprit. The guide that comes with the table saw (the one that fits into the grooves on either side of the blade) is extremely loose in the slot. I seriously doubt that the blade has been aligned with the fence, either, but I dont think that’d have much to do with it since I wasn’t using the fence.
Since I’m only borrowing the table saw and can’t make any modifications to it, what can I do to increase the quality of my dado cuts on this saw? I’m trying to make a bookshelf with lap joints and would really really like to have it as close as I can.
Thanks in advance for your help!
-- ~ Dan, North Carolina, http://www.BluewoodCreations.com
2 replies so far
View chrisstef's profile
chrisstef
5190 posts in 1171 days
#1 posted 278 days ago
You can use a marking gauge to set the distance of your lap joint and sneak up on it with the dado blade. Its nto a prefect fix but it should get ya darn close. Keep the setting of the gauge for each board and as long as they are cut square they should be identical from board to board.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View cutmantom's profile
cutmantom
188 posts in 1200 days
#2 posted 257 days ago
when making your cuts maintain a light side pressure, this will effectively cancel out the play in your miter gauge
