GFIC outlet and my Performax 10-20 won't play together.
Forum topic by Douglas Bordner posted 08-12-2012 03:41 PM 1595 views 0 times favorited 21 replies Add to Favorites Watch
Douglas Bordner
4024 posts in 4089 days
08-12-2012 03:41 PM
Topic tags/keywords: question sander
I had the GFIC circuit in the garage pop while sanding. Wasn’t trying to hog-off too much, halfway through a pass. Now as soon as it plugs in the GFIC trips, even when the conveyor and drum switches are off. I’ve blown it all out with a compressor and would like to get a look in the junction box behind the switch but can’t figure out how to pull the safety paddle switch in order to get in there. Can’t see a clip to access, nothing is visible under the lock-out. How do you get in there?
Thank you to all who respond…
21 replies so far
Douglas Bordner
#1 posted 08-12-2012 03:42 PM
PS, already replaced the GFIC…
View JollyGreen67's profile
JollyGreen67
1676 posts in 2788 days
#2 posted 08-12-2012 03:49 PM
Was going to recommend replacing. Mine did the same thing. I disassembled the old GFCI, just to see what the innards looked like – burned contacts.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View Handtooler's profile
Handtooler
1577 posts in 2158 days
#3 posted 08-12-2012 04:00 PM
Yes, a weak or faulty breaker would be the first culprit. Of course the circuit is ample for your machines load? Wire guage and breaker size. Russell
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View waho6o9's profile
waho6o9
8207 posts in 2602 days
#4 posted 08-12-2012 04:22 PM
I would try different outlets just to see what would happen.
Good luck my friend.
Douglas Bordner
#5 posted 08-12-2012 05:08 PM
Was running the DC too, and the sound system. But I have done so for years without issue. I’m pretty sure it’s in the tool.
All other woodworking pursuits are happening. It’s a 15 amp breaker at the panel, and I have popped it attempting to run the TS under load (binding) and don’t run it and the DC at the same time EVER. I usually run only one machine at a time and clean up afterward, but the drum sander has to be vacuumed as it runs. I may try plugging it in to a non GFIC circuit, just to see if I can bring the whole house to a stand-still. XD
Douglas Bordner
#6 posted 08-12-2012 05:08 PM
Anybody know how to pull that paddle switch?
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2882 days
#7 posted 08-12-2012 05:41 PM
I removed the cut off.
I just watch that I dont drive to thick a
piece through
Before I removed it I was waiting longer
for resetting than I was sanding.
jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
TopamaxSurvivor
18290 posts in 3701 days
#8 posted 08-12-2012 05:52 PM
It only takes 5 milliamps to trip the GFCI. You may be able to trouble shoot the machine with a good meter like a Fluke. I’m not sure if a cheap mete will tell you anything.
35125 posts in 4426 days
#9 posted 08-13-2012 12:06 AM
Douglas: I had a ground fault pop with just an electric eye on the circit som it doesn’t take much of a bleed for it to pop.
I would think that the bottom of the control area should be able to be removed and then you can get to the switch from there.
Just remember a ground fault doesn’t pop because of a short, it pops because on an inbalance of current from a hot wire (black) 0that doesn’t return through the ground side (White) so check from the white to the ground to see if there is a connection.
#10 posted 08-13-2012 12:08 AM
Does anything else pop the GFCI, Just the sander?
Douglas Bordner
#11 posted 08-13-2012 12:26 AM
Just the sander. The schematic shows a common ground post for the conveyor and drum. Some spider/cobweb blew out when I was cleaning it. There are two screws that attach the wiring box to the chassis, the rocker, a reset button with a screw on bezel and the potentiometer dial on the top for conveyor speed.
View Tennessee's profile
Tennessee
2873 posts in 2540 days
#12 posted 08-13-2012 12:34 AM
Remember that a GFCI is intended to pop when it senses any voltage going to ground. This also has to have a small amount of amperage with it, so the sensor can trip. Doesn’t take much at all, milliamps.
Also remember that the original use of GFCI is to prevent shock around water, so if water can carry the current with 120VAC, you will pop. People always think of a lighting bolt running through water, lighting is usually over 30,000 VDC. WAY more then a little 120VAC. So you have an amperage bleed somewhere in your sander, maybe even in the plug and wire.
All that being said, you may have a slight ground in multiple places in your sander, not just the switch. Any place where you might have dust from wood with any kind of dampness or minerals that would allow the windings to ground, the switch, any screw connection, the whole circuit!
View klassenl's profile
klassenl
185 posts in 2685 days
#13 posted 08-13-2012 03:35 AM
I would like to chime in here but I think my advice would be poo-pooed by most of the “experts” here.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View EEngineer's profile
EEngineer
1103 posts in 3639 days
#14 posted 08-13-2012 04:11 AM
GFCI compares the current in the “hot” wire with the current in the “neutral” wire. Any difference (a difference as little as 5 milliAmps will cause the GFCI to trip) between the two currents must be taking a different path than from the “hot” through the application to “neutral”. The most dangerous case is where that path is through a person’s body to ground, also known as electrocution.
Now, there are lots of possibilities for where the current path might be BUT the most common case is a breakdown in the varnish used as insulation on the wires in the motor windings. Except in the most extreme cases, you are not going to be able to measure that with a voltmeter. They generally drive the ohms function with a few volts. Varnish breakdown doesn’t show up until the voltage is 100 volts or higher. In general, you need a “hi-pot” tester (high potential) that measures leakage with a high voltage applied to the motor. Any decent motor shops will have this equipment.
TopamaxSurvivor
#15 posted 08-13-2012 04:26 AM
I can usually identify GFCI tripping issues with my ol’ Fluke 27. Motor testing does require a higher voltage meter. I can’t remember if I ever had a motor winding grounding causing the unbalance or not. I have done it too many times to remember them all ;-)) AS I recall, the Fluke usually shows about 3-4 mega ohms or less on a tripping circuit. Usually 6 mega ohms to infinity will be clear. I doubt if this helps much.
If the sander is the only thing tripping the GFCI, it is most likely 99.9% for sure the problem.
