Does woodweld plastic resin glue dry clear?
Forum topic by aimeebeme posted 280 days ago 447 views 0 times favorited 5 replies Add to Favorites Watch
View aimeebeme's profile
aimeebeme
2 posts in 280 days
280 days ago
Does anyone know if woodweld plastic resin glue dries clear? I am doing a paper mache project that I want to be durable and have a clear finish and have been pointed to woodweld for the durability aspect.
If woodweld is opaque, perhaps someone could suggest something else.
Thanks to the forum.
5 replies so far
View willie's profile
willie
412 posts in 620 days
#1 posted 280 days ago
Sorry, I’ve never used the weldwood. I have used polyester resin, the stuff used with fiberglass, to fill holes on a table made of wormy chestnut. It is not opaque but is not actually clear. You can see through it, depending how thick you make it. It is extremely durable and may serve your purpose. It is readily available at any auto parts store and is relatively cheap. Might be worth looking into.
-- Every day above ground is a good day!!!
4867 posts in 1813 days
#2 posted 279 days ago
Weldwood dries brown.
View DLCW's profile
DLCW
505 posts in 820 days
#3 posted 279 days ago
Dries a brown color. Also, since it is so HARD, don’t use a jointer or planer to remove squeeze out. It will dull your blades VERY fast. I use a belt sander to remove squeeze out.
I use the stuff all the time and love it!
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
820 posts in 659 days
#4 posted 279 days ago
Whoever handed you the advice got 1/2 of right, the Weldwood is durable. I’m not familiar with any glue that dries perfectly clear….just plain white glue may come as close as anything.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View RetiredCoastie's profile
RetiredCoastie
998 posts in 1348 days
#5 posted 279 days ago
I’ve used WELDBOND and it dries clear. I’ve used it on several projects and it works very well. Here’s a link:
http://www.weldbond.com/products
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
