How do I finish a burl?
Forum topic by amateur posted 311 days ago 439 views 0 times favorited 4 replies Add to Favorites Watch
View amateur's profile
amateur
89 posts in 854 days
311 days ago
I have three potentially beautiful slabs of big leaf maple burl and am having trouble with the finishing. Most of the wood I have worked is simply sanded in the direction of the grain until all the lines are out. These slabs have a swirling grain that doesn’t have a clear-cut direction. I seem to be adding almost as many lines as I am removing. What do you do?
89051 posts in 1774 days
#1 posted 311 days ago
Are you using a random orbital sander ? Normally on burl you would get the burl flat with perhaps a router sled set up then a belt sander and then go through several grits of sand paper with a ROS.
View Roper's profile
Roper
1333 posts in 1910 days
#2 posted 311 days ago
The best way to finish a burl is with a card scraper.
-- Roper - Master of sawdust-www.coloradocustomworks.com
#3 posted 311 days ago
Another good approach Roper
amateur
#4 posted 310 days ago
Thank you. I’m gonna try the scraper. If I have more questions, I will post them.
