Fixing spine on backsaw
« back to Hand Tools forum
Forum topic by Brett posted 08-11-2012 02:10 AM 1132 views 0 times favorited 3 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2677 days
08-11-2012 02:10 AM
If you’re familiar with backsaws, you know that the brass or steel spine is usually either parallel to the teeth or is slightly closer to the teeth at the toe (front) of the saw than at the heel (rear).
I bought an old saw online recently that is in great condition, except that the spine has slipped slightly so that the spine is slightly further from the teeth at the toe than at the heel. Is there a good way to re-align the spine with the teeth without damaging the teeth or the saw plate? Thanks.
-- More tools, fewer machines.
3 replies so far
View RS Woodworks's profile
RS Woodworks
533 posts in 3246 days
#1 posted 08-12-2012 05:03 AM
Clamp the saw plate tightly between two full length pieces of wood, then adjust the spine as needed. I have completely removed spines and reinstalled them using this method, no problem.
Ryan
-- I restore the finest vintage tools! If you need a nice plane, saw, marking tool or brace, please let me know!
Brett
#2 posted 08-13-2012 02:21 PM
Ryan, does “adjusting” including tapping the spine in place with a hammer?
RS Woodworks
#3 posted 08-15-2012 07:25 PM
Sorry for the delayed response Brett. Yes, I use a hammer, but never metal on metal. I use my wood or rubber mallet, or if you must use a metal hammer, be sure to use a wood block in between. I’ve never damaged a spine.
Ryan
