empty steal building
Forum topic by Eric posted 08-10-2012 07:14 PM 1582 views 0 times favorited 18 replies Add to Favorites Watch
View Eric's profile
Eric
28 posts in 3066 days
08-10-2012 07:14 PM
Hello All,
I have moved to Florida and on my property is a 30X50 completly open steal building. I am looking for some help on how best to add interior walls (steal or wood)? How do I fasten the walls to the building? Do I need to insulate? do I need to put in a cieling? and such….. The building does have 2 garage door (12’ and 9’ wide) and 1 entry door. I am going to make a wood shop 30X35 when all is said and done. If anyone has any helpful information let me know. thank you…..
-- Eric Florida
18 replies so far
View JAGWAH's profile
JAGWAH
929 posts in 2953 days
#1 posted 08-10-2012 07:25 PM
Eric, A steel building is a great start. Depending on the exterior walls you can run hat channel on them and this will allow you to screw plywood or drywall to that. As to walls metal studs be my choice,termites don’t eat metal. I would build my walls after I put in a drop cieling.This will be appreciated if in the future you decide to rearrange the shop. But I might leave my overhead clear around my equipment to allow for any dust collection . Even in Florida I suspect a well insulated building will be appreciated.
-- ~Just A Guy With A Hammer~
View MisterBill's profile
MisterBill
411 posts in 2120 days
#2 posted 08-10-2012 07:34 PM
Eric,
Where in Florida are you located? The reason that I ask is that the southern portion of the state has some of the strictest building codes around. As a starting point I would suggest that you contact the local building department to find out what their requirements are. After all, you don’t want to build your insulated walls and ceiling and then have a hurricane come along and blow it all away!
View grizzman's profile
grizzman
7836 posts in 3172 days
#3 posted 08-10-2012 07:37 PM
well this is great, what a way to start your new shop, i think using wood or steel will depend on what you like best, what is the best price, both will work, i dont have any experience with steel , and all in wood, so i think you can decide that, as to insulation, if your going to heat or cool the building, i would insulate, does it get cold enough there to have heat..i know it gets hot enough there to warrant cooling, and if you want to control the cost of either , i would have a lower ceiling..heat rises, in my shop i have 10 foot walls, and the ceiling is insulated, i also have wood heat for the winters, most of the days are ok without heat, but there is enough cold days that i want the heat, andi also cool my shop when it get to be to much, and it stays cool enough in there with what i have…your power will need to be evaluated, how many machines will you run that require 220, and how many will you have, when my shop was built i had a 220 amp service put in, and it gave me the options i wanted, my recommendation is to put in a lot of 120 receptacles..and run yourself a good dust collection , thats all i will post for now unless you ask me questions, as you might be a experienced wood worker, but il be glad to help if i can…grizz
-- GRIZZMAN ...[''''']
View AandCstyle's profile
AandCstyle
2945 posts in 2126 days
#4 posted 08-10-2012 11:53 PM
If possible, I would use painted OSB or drywall. Your machines will make a lot of noise and steel walls will amplify that noise. I once owned a kennel with steel walls and couldn’t hear myself think when a few dogs were barking (almost always). HTH
-- Art
View Dusty56's profile
Dusty56
11814 posts in 3557 days
#5 posted 08-11-2012 12:00 AM
steel
View DIYaholic's profile
DIYaholic
19481 posts in 2544 days
#6 posted 08-11-2012 09:19 PM
For my personal use, I would use padded rubber for the interior covering!!! Lol.
Definitely check local codes, prior to doing any “construction”.
View woodworker59's profile
woodworker59
560 posts in 2070 days
#7 posted 08-11-2012 09:29 PM
All I can say is ” what a terrible dilemma to have, what to do with a 30×50 shop” I will sit here in my little 11×20 and think of all the things I could do with that much space.. enjoy, great position to be in.. Papa (green with envy)
-- Papa...
View Bill White's profile
Bill White
4813 posts in 3829 days
#8 posted 08-11-2012 09:49 PM
+1 on “steel” unless ya stole it.
Codes are a big deal. Check ‘em out before ya build.
Bill
-- bill@magraphics.us
Bill White
#9 posted 08-11-2012 09:49 PM
View Tom Clark's profile
Tom Clark
88 posts in 2890 days
#10 posted 08-12-2012 03:08 AM
Eric, I just moved from FL to NM.. I had a 40×60’ building for the last 14 years in FL, and now have a 36×60’ at the new place. The old building had R11 insulation walls and ceiling from when the building was built. Heat and air cost was HIGH! First photo shows the old shop as we were moving out of it.
In the new building I divided the building into a 36×36 shop, a 24×24 garage, and a 12×24 exercise room. When the walls were built I used studs on 2’ centers, since they do not support the roof. Behind the walls we added 4×8’ sheets of 2” thick styrofoam on top of the insulation the builders put in. Studs were bolted to the inside of the walls, and concrete screws were used in the floors. Wiring was run thru the walls and electrical boxes installed before the 7/16” OSB walls were put up. We painted the walls with white primer, because the unpainted walls started looking like a dungeon inside the shop. With the well insulated shop it stays quite cool all day, even when it is 100 degrees outside. With the good insulation air-conditioning is easy and inexpensive.
-- Tom
View Knothead62's profile
Knothead62
2581 posts in 2830 days
#11 posted 08-13-2012 05:41 PM
Tom, skip the exercise room and use it for more shop area! :D
grizzman
#12 posted 08-13-2012 06:41 PM
im thinking tom wants to be around longer to use his shop, so i imagine the exercise room has a purpose…lol…
View Doss's profile
Doss
779 posts in 2133 days
#13 posted 08-13-2012 06:59 PM
—> im thinking tom wants to be around longer to use his shop, so i imagine the exercise room has a purpose…lol…
Just get a old jointer and a tablesaw and store them at the beginning and ending of each day with no mobile base.
Restack your lumber 3 times a week.
Done.
Oh, about the walls. I’d get an estimate from a spray in insulation company to keep your conditioning bills down.
Then, you can do the traditional method and use one of the systems available (probably through the bldg manufacturer or others) to add walls to a steel bldg OR build stand alone rooms or partitions around the shop to allow some flexibility in space utilization.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View jm8's profile
jm8
69 posts in 2181 days
#14 posted 08-13-2012 10:09 PM
Tom I am so jealous. Sure beats my 10×20 space.
Peace to all
-- Joe from Western Ma.... Peace to all
Tom Clark
#15 posted 08-14-2012 06:51 PM
YA DARN RIGHT!
SORRY, I DON’T MOVE MACHINERY. ALL IS STATIONARY
I JUST FINISHED UNLOADING THE SEMI WHEN WE MOVED, AND GOT IT STACKED THE WAY I WANT IT! AND YOU WANT ME TO LOAD AND UNLOAD THREE TIMES A WEEK????? SEE PHOTO…
I JUST BOUGHT 53 SHEETS OF 2”X4’X8’ FOAM FOR $954. THAT IS 1/3 THE PRICE OF SPRAY-ON.
SEE PHOTO IN LAST POST. I BOLTED THE STUDS TO THE STEEL WALLS AND IT WAS EASY AND CHEAP TO DIVIDE INTO ROOMS – USING THE FOAM AND OSB FOR PANELING.
-- Tom
