How to achieve large angles on a Miter Saw
Forum topic by Bradley Mitchell posted 08-10-2012 11:56 AM 16327 views 1 time favorited 11 replies Add to Favorites Watch
View Bradley Mitchell's profile
Bradley Mitchell
6 posts in 2565 days
08-10-2012 11:56 AM
I cannot for the life of me figure out how to achieve a 150 degree angle using a miter saw. I’m just too stupid to figure it out. Please inform the dumb.
11 replies so far
View CampD's profile
CampD
1619 posts in 3358 days
#1 posted 08-10-2012 11:59 AM
150 – 90 = ?
-- Doug...
View ksSlim's profile
ksSlim
1264 posts in 2761 days
#2 posted 08-10-2012 12:55 PM
Or 180-150=? Miter saw bed is 180 degrees side to side. Blade is normally set at 90 deg to bed.
-- Sawdust and shavings are therapeutic
View Doss's profile
Doss
779 posts in 2136 days
#3 posted 08-10-2012 03:08 PM
What shape are you trying to cut?
From how it appears mathematically (board stock completely across), you can use either 60° if your saw allow that or 30°. The saw itself will not allow 150° as a direct cutting option due to its design (would most likely interfere with the fence getting cut or the saw mount rotating into the saw base) and the impracticality of such a cut.
-- "Well, at least we can still use it as firewood... maybe." - Doss
404 - Not Found
2544 posts in 2841 days
#4 posted 08-10-2012 03:12 PM
Look at Rembo’s project, he made a great jig for this type of cut. You have to turn the piece perpendicular to the fence.
http://lumberjocks.com/projects/59225
116804 posts in 3449 days
#5 posted 08-10-2012 03:15 PM
You can do it if you set your miter up this way.
http://lumberjocks.com/projects/47426
or from that same post
http://www.sawdustmaking.com/Radial%20Arm%20Saws/radial_arm_saws.html
View Doss's profile
Doss
#6 posted 08-10-2012 03:30 PM
I guess I’m just having trouble visualizing what Bradley is trying to do. Here’s what I am thinking:
Are we talking about something entirely different?
4827 posts in 2365 days
#7 posted 08-10-2012 03:54 PM
I’m thinking you need a right angle fence.
Bradley Mitchell
#8 posted 08-10-2012 08:21 PM
Thanks for the replies. Here is what I’m building: http://www.appropedia.org/Hexayurt_H13_Plywood
And here is a picture of the angled blocks:
It looks like I’d need to set my saw to 30 degrees to achieve the 150 degree block. But this is a bit confusing because I also need to create several blocks at 120 degrees. I thought to achieve this, I’d need to do this: 120-90=30. So if I set my saw at 30 for a 150 angle block, what should I set it at to get 120?
So confusing.
View Doss's profile
Doss
#9 posted 08-10-2012 09:11 PM
Let me know if this is confusing:
When I say flip over, I mean literally flip it over (not rotate).
Bradley Mitchell
#10 posted 08-10-2012 09:29 PM
Yes that helps a great deal. Thank you so much and my apologies for my ignorance.
View Doss's profile
Doss
#11 posted 08-10-2012 09:57 PM
It’s not a problem. Hopefully you can read that image. From the looks of it that is what you were trying to accomplish right?
The center is the 150° angle. Yellow = 30°. And Orange (though it looks like red… there should be one right next to each yellow) is 60°.
The difference on the 120° is the Yellow is now 15° and the Orange is 75°. That give you 120° in the middle.
