Usable? 50 yr old 12" 4/4 reclaimed red oak
Forum topic by SchottFamily posted 282 days ago 506 views 0 times favorited 11 replies Add to Favorites Watch
View SchottFamily's profile
SchottFamily
110 posts in 659 days
282 days ago
I just bought a house that was built in 1965 and pulled a half dozen 15’ 12”x1” of what I think are red oak shelves out of the garage. I’m assuming they’re original to the house because of the nails used to secure them to the plaster slat walls. I would HATE to just throw them out if I didn’t have to.
Anyhow, the boards are very dry to the touch, but free of defects. Since the garage isn’t sealed or climate controlled – what kind of success do you think I would have in reusing them for some shop projects? They’re beautiful as they are, but as dry as they are, I was thinking stands for my joiner and planer. If I’m mistaking dry for dry rot, then I don’t want to take the chance. One of the boards didn’t pull free, but split in two when taking them down from the wall.
-- IZZZZZI BoB IZZZZZI
11 replies so far
View knotscott's profile
knotscott
4181 posts in 1541 days
#1 posted 282 days ago
If they’re stable, I’m sure you could use them for lots of things. It doesn’t really look like red oak to me in that pic….can you take a couple of others that show more of the board and grain?
View Howie's profile
Howie
2448 posts in 1089 days
#2 posted 281 days ago
Doesn’t look like oak to me (MHO) Whatever they are if they are in good shape you have some great lumber.
Build something nice out of them.
-- Don't rollerskate in a buffalo herd
View WDHLT15's profile
WDHLT15
682 posts in 642 days
#3 posted 281 days ago
They should work fine for about any project.
-- Wood-Mizer LT15
View RickLoDico's profile
RickLoDico
55 posts in 1227 days
#4 posted 281 days ago
From that one pic it looks more like cherry than oak. Either way they’ll be fine for any project. they’re not going to be “too” dry. If you have a metal detector, check for any hidden nails.
-- He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.
View Zinderin's profile
Zinderin
93 posts in 298 days
#5 posted 281 days ago
Let them stabilize where you’re going to use them, I would think.
Please, you “wood whisperers” correct me if I’m wrong (I’m no expert), but I was taught wood will draw in moisture just as easily as it will expel it. That’s why wood stabilized and used in the high desert can have issues if you bring it to a beach house. Right? Wrong?
View ksSlim's profile
ksSlim
800 posts in 1056 days
#6 posted 281 days ago
Depending on finish or lack thereof, all wood will attempt to allow moisture to move in and out to equalize with the environment.
The rule of thumb I was taught, the denser the wood, the more lateral (width wise) movement.
Always good to allow wood to stabilize in the area of use. After “climatized”, mill to rough size and watch for movement for a week or two before final milling and assembly.
-- Sawdust and shavings are therapeutic
View bondogaposis's profile
bondogaposis
1237 posts in 517 days
#7 posted 281 days ago
From the picture, I’m thinking cherry also. I would think that they would be fine for just about anything.
-- Bondo Gaposis
View ssnvet's profile
ssnvet
1526 posts in 494 days
#8 posted 281 days ago
Wood is good…. please don’t thow those babies away….
-- Matt, Pine is fine, but Oak's no joke!
View chrisstef's profile
chrisstef
5204 posts in 1172 days
#9 posted 281 days ago
The majority of what i use is reclaimed lumber. It can be a pain in the neck to dimesion it but like you got yours it usually FREE. Use it ! At very worst its good stuff for shop cabinets and shelving.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View wiswood2's profile
wiswood2
841 posts in 1862 days
#10 posted 281 days ago
That aint oak. I would say cherry. I got some 100 year old oak out of a hotel that was tour down.It is great to work with.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View JohnEinNJ's profile
JohnEinNJ
71 posts in 513 days
#11 posted 281 days ago
definitely get a metal detector – the Rockler Little Wizard is only about $20, and works fine.
