Charles Neil Tapering Jig Question
Forum topic by Chris208 posted 08-10-2012 06:43 AM 1988 views 0 times favorited 7 replies Add to Favorites Watch
View Chris208's profile
Chris208
239 posts in 2294 days
08-10-2012 06:43 AM
I built this jig, and had a good time doing so.
But, I can’t figure out how to use it to do a four sided taper.
Anybody else using this jig that can help?
7 replies so far
View Tomj's profile
Tomj
204 posts in 2406 days
#1 posted 08-10-2012 06:58 AM
Usually when I do a four sided taper I have to tape or hot glue the cut pieces back on to the already tapered board so I have a flat side to use for the additional tapers but I’m not sure how this particular jig works or if you already know this. Just trying to help. Good luck
View sonnyr's profile
sonnyr
131 posts in 2152 days
#2 posted 08-10-2012 11:35 AM
Found this on the internet, helped me out.
http://www.youtube.com/watch?v=bV2j3T-ojfs&feature=related
-- I may be slow, but I'm easy to stop!!!
View CharlesNeil's profile
CharlesNeil
2410 posts in 3895 days
#3 posted 08-10-2012 12:59 PM
its a 2 step process, draw the size of the foot you want, and of course the exit point, set the jig up as you normally would for a 2 sided taper, but of course your removing a much smaller amount because you will be removing material from both sides, then cut 2 sides, then re adjust the jig to cut the other 2 sides, you have to do this because you removed material from the 2 sides , so you have to readjust to compensate for it. Hope this makes sense,
Chris208
#4 posted 08-11-2012 03:29 AM
Thanks for the responses, all. Very helpful.
Thanks for the plans and videos, Charles. Very generous of you.
View Zinderin's profile
Zinderin
94 posts in 2157 days
#5 posted 08-11-2012 01:25 PM
Cut two opposing sides, tape the waste pieces back on using shims if needed, then cut the other two sides.
I think the guy in the video above makes it more complicated than it has to be … but then a lot of the youtube videos make things much more complication than necessary.
It amazes me how men who spend so much of their life alone in their “cave” can suddenly become the captain of their speech team when the camera gets turned on.
117115 posts in 3601 days
#6 posted 08-11-2012 01:47 PM
Chris
I think a talented woodworker like Charles Neil who makes 40-60 major pieces of furniture a year, has at least 40 videos on you tube has a weekly on line woodworking class teaching both woodworking and finishing might know how to use his own taper jig. I’m sure you know this already.
View Jim Finn's profile
Jim Finn
2657 posts in 2946 days
#7 posted 08-12-2012 12:34 AM
http://theinquisitivewoodworker.com/wordpress/tapering-jig/
I made one similar to this. No cutting and taping pieces while using this jig with an indexing pin.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
