Having trouble jointing on my jointer
Forum topic by BerBer5985 posted 08-10-2012 04:19 AM 3120 views 0 times favorited 19 replies Add to Favorites Watch
View BerBer5985's profile
BerBer5985
445 posts in 2505 days
08-10-2012 04:19 AM
I have an old Craftsman 36” long jointer 6” wide. I’ve set all the knives with the one way jointer setup tool. When I do shorter pieces I don’t seem to have a problem, but longer thinner pieces, I have a hack of time getting them square. I’d love to upgrade the jointer at some point, but it’s driving me crazy that I can’t get pieces square quickly. Either the jointers not long enough, or my technique is not great. Thicker stock seems to work out ok, but thinner (like 3/4”) becomes very difficult for me. Any tips?
-- Greg, Owner, Quality Carpet One, www.qualitycarpetonecrofton.com
19 replies so far
View Tomj's profile
Tomj
204 posts in 2466 days
#1 posted 08-10-2012 07:05 AM
I’m just curious, is this a model 113 Craftsman Jointer? I have one of these. It was my fathers and he only used it twice. The second time he put a board with a screw or nail in it through the jointer and chipped one of the blades. I am in the process of restoring it. It has sat in the basement for over 15 years rusting away. Sorry I can’t offer any tips as I myself am still learning jointer technique. Good luck.
View Roger's profile
Roger
20931 posts in 2888 days
#2 posted 08-10-2012 11:36 AM
I had one of these. I had to shim the fence with a playing card or 2 to get it square. You just gotta keep playin and tweekin it constantly. Save yer money and get a better jointer. That’s my 2-cents
View JJohnston's profile
JJohnston
1622 posts in 3376 days
#3 posted 08-10-2012 12:18 PM
It could be that the boards have some warp to them, but because they’re thin, you’re flattening them out when you press them down onto the tables. They spring back after the cut, and they’re still warped. Is that what you mean?
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View muleskinner's profile
muleskinner
897 posts in 2521 days
#4 posted 08-10-2012 12:32 PM
I had an old Craftsman 4” jointer (also my fathers) that I had the same problem with. I determined it was my technique. The low height of the fence was such that I had trouble keeping wider boards perpendicular when edge jointing. I finally attached a wider board to the face of the fence that made it easier. My technique still sucked but the results improved.
-- Visualize whirled peas
View Alexandre's profile
Alexandre
1417 posts in 2275 days
#5 posted 08-10-2012 12:42 PM
Did you set the out feed table after changing the knives?
-- My terrible signature...
BerBer5985
#6 posted 08-10-2012 01:09 PM
I’m not sure the out feed table is adjustable. The knives are all perfectly square to the out feed table but it’s like my stock seems to be coming out much thinner on one end then the other. I’m not sure why. The fence is dead square to the table as well. Maybe the boards are that warped. It just doesn’t seem like its taking even amounts of stock off. I’m
In the process of trying to upgrade to a better jointer. I’d like one with a longer table for sure. This jointer I believe was made in the 1960s. It’s all solid cast iron. Including the stand. It’s heavy for its size.
muleskinner
#7 posted 08-10-2012 01:25 PM
Greg, if you’re trying to get parallel edges with a jointer you’re in for a lot of frustration, at least I was until I figured out that the jointer was good for getting one flat edge and then paralleling (?) it up on a table saw or planer.
View Mainiac Matt 's profile
Mainiac Matt
8274 posts in 2413 days
#8 posted 08-10-2012 01:28 PM
post a pick of the jointer… there are several different models of old Craftsman jointers….. some better than others.
-- I yam what I yam and that's all what I yam
View Handtooler's profile
Handtooler
1620 posts in 2217 days
#9 posted 08-10-2012 01:51 PM
Alexandre, The Craftsman jointers do not have an out feed table adjustment. Berber 595, Its necessary to install the blades such that when a small narrow board is placed across the infeed table, cutter head and out feed table; and the cutter head is rotated by hand. that as the blade comes in contact with the board it moves the board ahead about 1/2”. the height adjustment jig with the screw twisted out 21/2 turns, I believe is what the owners manual calls for, sets rhe blade height almost correctly. I finally got mine to stop snipe and joint edge and face correctly after I reset my blades this way having read a tip only last year. I purchased miine later 70’s.
And, yes I want to upgrade to an 8” machine with an adjustable out feed table and one with more HP.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
BerBer5985
#10 posted 08-10-2012 03:11 PM
Ok, here’s what I’ve got. I checked to see if the tables were coplanar, and from the measurements, they are. I also checked to see if maybe the knife holder was in line with both the infeed and outfeed tables and it’s within .004” off from left to right, but the knives are square to both. The knives are all reading .001-.002” above the outfeed table. The only thing I can think of if my technique is horrible, like I’m overpowering the wood while pushing it through and putting too much pressure, or I’m trying to joint too long of boards in a 36” long jointer, or the boards are just that twisted.
View Tomj's profile
Tomj
#11 posted 08-11-2012 02:19 AM
Wish I could help but I’m still in the process of getting mine together. Mine is newer maybe 91-92, it’s a 113 206 932 Craftsman Jointer. Good luck.
JJohnston
#12 posted 08-11-2012 02:29 AM
Jointers aren’t supposed to keep, or make, opposite faces parallel. What yours is doing is perfectly normal. All a jointer does is get one face flat, and one edge flat and square to the flat face. The planer makes opposite faces parallel. It’s normal that the more you joint a piece, the more of the taper effect you get. It will also taper side to side in addition to end to end.
View fussy's profile
fussy
980 posts in 3135 days
#13 posted 08-11-2012 04:01 AM
What JJohnston and Mule Skinner said. A jointer will flatten one side and square one edge to that side. That’s all it will do except eat lumber and turn it into chips if you keep trying to make 4 square lumber on it. There’s nithing wrong with it. It’s just not meant to do what you are trying to do with it. That’s what planers are for. And you thought woodworking was going to be a CHEAP hobby?
Steve
View Grandpa's profile
Grandpa
3260 posts in 2760 days
#14 posted 08-11-2012 04:07 AM
What JJohnston said about making one side and edge straight. Then complete the job with a saw and a planer. I have a jointer similar to this one from the late ‘70’s. I had problems somewhat liek this when planeing the first edge. I ginally found that I had a knife that was not up to the outfeed table surface. I read about a technique that said to use a sharpening stone with a piece of paper around it.
Put the stone on the outfeed table and work the knives with it. This should leave the knives about .003 above the outfeed table and parallel to the table. Mine works well and has for years. It is a 6 inch jointer with a short table so keep that in mind. A Cheverolet doesn’t ride like a cadillac.
BerBer5985
#15 posted 08-14-2012 02:45 AM
I know that the jointer only flattens one side but it’s not even doing that. I’m kind of thinking the jointer might be underpowered. I found that after I set the knives on my old ryobi benchtop, I was getting better results. I’m not sure what the deal is. Im going to sell both here soon and buy a new one anyway, but I don’t think the knives are spinning at a high enough rpm and the motor is only 1/2 hp. I’m thinking that possibly part of the outfield table is not perfectly flat and I’m setting the knives to be even with either a low or high spot and it’s messing up the results. Who knows, all I know is that I’m frustrated with it. I was dimensioning stock by hand for a while and that’s just tiring, so I busted out the power machines for dimensioning stock only to leave frustrated. When it’s taking 15 mins on each board and eating away at the stock to leave me with just a flat edge, then it’s not worth it. It could also be the fact that it’s 3/4” stock of pine and it’s just bending under pressure and I’m just removing stock without fixing the defects. I’m sure it’s not all the jointers fault, but I’m sure there’s a lot that would be improved with a new machine.
