Bending green wood into oval boxes
Forum topic by TopamaxSurvivor posted 08-10-2012 03:59 AM 1734 views 0 times favorited 9 replies Add to Favorites Watch
TopamaxSurvivor
18246 posts in 3640 days
08-10-2012 03:59 AM
Topic tags/keywords: bending green wood steam ash
Today I spotted a fresh cut ash log about 20 ” in diameter. I was too late and it had been cut up for fire wood. I got to thinking about how I was going to do it and, quite frankly, I didn’t have a clue! ;-(
My first thought was to quarter saw & rive it in lengths of about 6 feet or a little longer getting it to about 1/4 to 3/8” thick. I thought I would plane it with a hand plane. Next move was to bend it on the form green. If that didn’t work too well, try steaming it and bending it green and wetter. If that didn’t work too well, let it dry, get a good finish and steam bend.
My biggest concern about doing the bending wet was being able to get a good smooth surface on, especially, the inside and the outside of a curved surface. I expect teh grain would be raise quite a bit by the time it got dry. Anyone know how that would have turned out?
Any ideas about the proper procedure?
9 replies so far
View bluekingfisher's profile
bluekingfisher
1250 posts in 2944 days
#1 posted 08-10-2012 07:00 AM
Bob – Not my area of expertise but i do remember watching a NYW show where the chap (I think his name was Mark Dungske????) was splitting trunks of about 6’ long. It looked a simple process, using only hand tools he was splitting the trunk into staves, hand planing, then steaming in a home made steamer.then forming the staves to make his windsor chairs. he reckoned this would provide more stable timbers as the hand tool method followed the natiral lines and contours of the grain. I think too the trunks had been felled 3 or 4 days previous. This all took place during the winter monthns when the sap in the tree was not at it’s highest.
f you are after turning the trunk into planks or boards then I’m sure it could be done in a similar pricess but there woulkd be a lot more waste.
I can’t remember much more but perhaps someone has the show taped and could provide you with more detail.
Good luck
David
-- No one plans to fail, they just, just fail to plan
TopamaxSurvivor
#2 posted 08-10-2012 07:07 AM
I’ve seen Roy on NYW doing riving with green wood a couple of times. He is always making round parts on the shaving horse when he rives green wood.
My biggest concern is what kind of finish will the curved board have? I expect it might be all fuzzy or grainy from being green and continuing to dry. If I need to smooth it, how to get on the inside curve and do a nice job?
OR = is it better to get it fairly dry, plane it smooth and then steam and bend?
bluekingfisher
#3 posted 08-10-2012 07:14 AM
From memory, the timber has to be “wet” to utilise it’s natural elastisity.
I guess the most appropriate tool for shaving the inside radius would be a spoke shave or drawknife…...........or if you are lucky enough to have one, a compass plane.
The guy was building chairs so I expect he was happy with the smoothness of the grain, although I can’t remember what the timber species it was he was working.
View Wildwood's profile
Wildwood
2297 posts in 2099 days
#4 posted 08-10-2012 01:17 PM
Not sure wood has to be green (wet) you will end up soaking wood slats in hot or boiling water. Plenty of insructions on making Shaker Boxes on the web.
-- Bill
View stefang's profile
stefang
15881 posts in 3298 days
#5 posted 08-10-2012 05:57 PM
I’m not sure what your goal here is Bob. A wood surface can always be smoothed once it is dry. If it is curved you can use a rounded card scraper or a rounded spokeshave or other suitably shaped edge tools used to shave inside curves. It is a lot easier to work green wood with the shaving horse whatever shape it is.
A lot of oval boxes here in Norway are made from birch bark which is very water proof and easy to work and also to punch holes in and sew together. Indian canoes are a good example of this. The layer just under the outer bark is wooden colored (light tan) and is the best part to use. There are many articles on the net about Birch bark and also using it make the oval boxes (search Birch Tine).
TopamaxSurvivor
#6 posted 08-10-2012 06:19 PM
Hi Mike, My greatest concern is the box is a flat piece of wood 3-6” wide bent in a oval. I am wondering if I get it smooth while lit is green and bend it, will it still be fairly smooth and not require much more than a light sanding?
All of the articles i have seen about making these boxes were using dry wood and steaming it as far as I know. When I saw the ash log, I thought, why not bent it green and/or add a little steaming if necessary, then let it dry rather than drying and finishing the board, then steaming?
I have some short fire wood lengths. I’m gong to make a small piece and bend it around a radius to see how it turns out. Not any where long enough to make an oval box ;-(
I gotta get some of these bucket list projects going. I keep adding more! ;-)
TopamaxSurvivor
#7 posted 08-10-2012 06:22 PM
I’m thinking if the oval is not a flat after being bent green, it will be impossible to flatten vertically with the horizontal axis being curved. Well, maybe not impossible, but more trouble than it is worth.
View studie's profile
studie
618 posts in 3111 days
#8 posted 08-11-2012 04:44 AM
Bob I just saw a wood mag article using a pvc 4” tube and a Rockler steamer unit. After steaming, then a buck made to the curve held it for an hour or so but I think you may have to leave green wood in the buck for a year or so;))
-- $tudie
TopamaxSurvivor
#9 posted 08-11-2012 05:08 AM
OOH! never thought about that ;-( Thanks
