| Forum topic by Howie | posted 286 days ago | 1038 views | 1 time favorited | 19 replies | ![]() |
286 days ago |
Are you satisfied with having a router mounted on the TS over a cabinet mounted router? Would you do it again? -- Don't rollerskate in a buffalo herd |
19 replies so far
#1 posted 286 days ago |
I have Bench Dog router table with a 3 1/2HP Bosch router and this combination works very well for me. #1 you do not have to make or to buy a cabinet= you save time and money. #2 you get a larger TS table to accommodate larger pieces to cut. #3 you do not need to find the room/place for one more thing in your shop IMO this is the best solution. -- Bert |
#2 posted 286 days ago |
I have a router mounted on one wing of my table saw, and for me this is the best solution, since I don’t really have the floor space for a stand alone router table. I like the large work top that is available with the TS, plus I can use the table saw fence to attach different guides that I use. I would recommend a cast iron wing with the router mount in it, just for the sturdiness of it. -- Tim-- http://www.tmuli.com |
#3 posted 286 days ago |
Howie; Don’t think I would like working height of router in end of my table saw. The top of my router cabinet is 46 inches and very comfortable height for me. I am 6 ft. tall. My miter saw cabinet is same height. Good luck! -- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas |
#4 posted 286 days ago |
I used a TS mounted router for several years before I had room for a stand alone table. No doubt the stand alone has several advantages (storage, simultaneous use with the TS, better DC, etc.). But I never felt disadvantaged with the one in the TS wing….and there is that big room savings part. The only thing I couldn’t figure out was a good dustcollection arrangement under the wing. My saw was on a mobile base so I couldn’t build anything heavy under it (that end of the saw was lifted by the base). I chose to just live with the clean up. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#5 posted 286 days ago |
I had a Bench Dog table in the left side of my unisaw and loved it. The table from the saw gave a lot of extra support that you cannot get from a stand alone router table. In addition you can also use the TS fence as an auxillary fence. I have since sold the unisaw but kept the router table. I now have it mounted to the left side of my Oliver. I like it and for someone who is limited on floorium it a perfect option -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
#6 posted 286 days ago |
A TS router table is a matter of necessity to me. It’s a compromise from a separate stand alone router table, but it’s a tremendous space saver that is a very reasonable compromise IMHO. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#7 posted 286 days ago |
I went round and round about this one too. I had a lot of ideas for different router table cabinets I was thinking about building. In the end, I ended up using a 20% off coupon from Rockler and getting the BenchDog router table extension wing like others have mentioned. It was kind of pricey, but I probably could have spent close to the same amount building a cabinet and outfitting it with t-track and a fence. In the end I was able to install the table saw extension in about an hour and was using it that same evening. I love the extra support it gives me on my saw when cutting sheet goods. I even took the wing I had on there before and moved it to the other side. I wouldn’t change a thing about my setup. |
#8 posted 286 days ago |
I had the chance to use the TS router table that came with my old Ryobi BT 3000. I found the bit to be too low and it made it harder for me to see what was happening, especially on blind routerings where I had to stop at a defined point. I bought a PC table that I put on a stand, then upgraded to a Bosch which I love. My table saw extension for me makes a much better workbench and I use it as such. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#9 posted 286 days ago |
Recently I was able to purchase the Incra TS/LS Combo – 1 ( router on left side of saw) mounted on a Rigid TS3650. Love the accuracy and repeatability. There are plans for extra dust collection that include a box mounted around your router. I am finding out though , I need to plan out my projects better, (read the instructions), because I have had to work around needing to rip an additional board after I have “zeroed/centered the router bit”. Space/money was the driving point for the combo set, if I had more I would have opted for separate components. -- I may be slow, but I'm easy to stop!!! |
#10 posted 286 days ago |
Mine is mounted with my ts as well. It’s that way because I was in the right place at the right time, so to speak, when I was first settin up my ts. A friend was gettin rid o his ts top, so, well, I got it. I had to make a few adjustments here n there, but, it works for me for now. -- Roger from KY. Work/Play/Travel Safe. Kentuk55@bellsouth.net |
#11 posted 286 days ago |
TS mounted router, Incra LS-TS 32 with the wonderfence router table fence. By far the best and cheapest method for an outstanding router table AND table saw set up. |
#12 posted 286 days ago |
Howie, After taking a quick look at the TS extension & where the router would be, I decided I would NOT like it. I went with a dedicated Router Table… and I am not sorry of the decision… I can setup a Router operation and leave it until I am completely done with it… without any conflict from a table saw setup messing it up, etc. I like it this way… seems to be more functional for me… -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#13 posted 286 days ago |
I do have issues sometimes with the router in the TS, but I’ve been using my new craftsman router in the table when I have to switch between router and TS a lot. The really nice thing about the craftsman setup (I reviewed that router, the professional one) is I can drop the motor from the fixed or plunge base without messing with height adjustment at all. It takes two seconds to pop it back in and get to routing. |
#14 posted 286 days ago |
I had this one got rid of it. I like separate tools much better. Maybe my style or inexperience, but it just wasn’t working for me. Lots of folks like it, I tried to. The space savings wan’t worth the downside. -- It must be jelly baby, cause jam don't shake like that... |
#15 posted 286 days ago |
I have a Benchdog TS router table/TS table extension and I wouldn’t change a thing …. except get another one for the other side of my TS. The Benchdog extension is so much better than the Craftsman extensions I have. Having the router table as part of the TS may require a little more planing of the work sequences i.e. the router is set up and crosscutting a long piece means altering the RT set up. Think ahead a bit more! -- "I never met a board I didn't like!" |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15786 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
