| Forum topic by HokieMojo | posted 47 days ago | 235 views | 0 times favorited | 5 replies | ![]() |
47 days ago |
Well, I’ve been working on building a sanding supply cabinet that is being made out of some of the less desirable piece of my walnut stash. I glued up a solid top and bottom to the cabinet and was going to make the sides out of plywood panels, set inside rails and stiles. I should point out that, I do not have a jointer of any kind. The rails and stiles for the sides are 3” wide and 3/4” thick and because there is no jointer, there is a slight bow to all the stiles and the rails are too short to tell (maybe 6”?). I cut the mortises I using a straight router bit on my router table. when I fit the joints, it seems that the mortises were cut crooked (the top of each joint is recessed and the bottom is proud). My fence was a straight piece of mdf against a plastic fence so there was no flexing no matter how hard I push. Do you think the poor result could be from running a curved board along the fence? When I hold the stiles against each other, each bowing out, the total gap is 1/2” in the middle of the boards so i guess it bows about 1/4” inch each over the 3 ft length. I figured the effect would be negligible. I know the question is not phrased wonderfully, but any thoughts? |
