Motorized Drill Press Table Lift
Forum topic by sonnyr posted 08-08-2012 03:10 AM 9826 views 2 times favorited 6 replies Add to Favorites Watch
View sonnyr's profile
131 posts in 2062 days
08-08-2012 03:10 AM
Topic tags/keywords: drill press table drill press
I inherited this Craftsman floor model drill press from my father. It did not have a rack and pinion set up, so when I wanted to get serious about adding a woodworking table, I knew I would have trouble raising and lowering it. The solution that I came up with was to build a cabinet underneath and use an electric car jack as a lift on top of the cabinet. The main table is approximately 23”X36”. It was part of a desk cubicle top. The 12V Automotive Tire Jack ($54.93) and the 10Amp 13.8 volt supply ($45.77) were purchased on The base is made from “cabinet grade” plywood from HD. The table support brackets were home made out of old bed rails. I’m not sure if the supports will get in the way of other jigs. For storage I added drawers to the right side of the base cabinet. I am planning to attach other drill press tables to the main table, along with other jigs as needed. The travel on the lift is about 9 inches. The base cabinet is 29 ½” high, 36” wide and 24” deep. The 4 drawers are approximately 13” X 20” X 3 ½”. I had to turn the floor support around for better clearance in front. The lift is a little slow but really works great when you need to lift or lower the table.
I have additional earlier pictures and a video on youtube.
After viewing this one, if you want a good laugh, you can also watch another video there, just click on “2 videos”. It’s about installing a Jet AFS1000B air filtration system. Had a lot of fun making that one but it is really dorky. Excuse the Texas accent.
-- I may be slow, but I'm easy to stop!!!
#1 posted 08-09-2012 02:19 PM
Drawer view
View DIYaholic's profile
19580 posts in 2608 days
#2 posted 08-09-2012 09:13 PM
I have a bench top DP. It too came without the geared rack for table hieght adjustment. I may need to steal your “motorized” table idea.
Thanks for sharing this.
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2118 days
#3 posted 08-09-2012 09:25 PM
I have that same drill press and it has a rack and pinion adjustment with a large lever
#4 posted 08-09-2012 09:38 PM
DIY, steal away. I couldn’t find this idea on the internet, after I “thought” of it, but I bet if you were to look hard enough, it’s out there.
Cole T, I weighed the idea of finding a rack and pinion setup to replace the lack of one on my drill press or trying the scissor jack approach, I just couldn’t find any replacement parts, and if I had, I thought that it would probably cost more than the $100 that I spent on the jack and 12V supply.
Thanks for the posts.
View crashn's profile
528 posts in 2399 days
#5 posted 08-10-2012 12:16 AM
nice idea. I almost scored a free hospital bed with motorized lifts, but by the time i came back with the truck it was gone. Those motors would have been a good deal for this application! and the cost (free) is right up my pocket books alley
-- Crashn - the only thing I make more of than sawdust is mistakes
View Planeman40's profile
1126 posts in 2694 days
#6 posted 08-10-2012 01:32 PM
I did the same thing but used a trailer jack on my old late 1950’s Craftsman floor mounted drill press. The trailer jack is one from Harbor Freight ( I extended the top of the shaft with a length of pipe, cut off the mounting gear from the side of the shaft with a 4” grinder, and removed the wheel from the bottom of the shaft. Works great! Lifts and lowers that heavy table with ease and operates from the front.
