cheap dust collection system
Forum topic by Mark Shultz posted 08-07-2012 05:21 PM 8658 views 6 times favorited 36 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
106 posts in 2471 days
08-07-2012 05:21 PM
Topic tags/keywords: dust tip
I was pondering PVC vs flex tubing for my new dust collection, when i stumbled upon this product from home depot. it is called TripleWall, and i believe designed for drainage applications. It cost about $7 per 10ft section, which is way less expensive then flex or PVC. there are end caps, whye’s , T’s also. connections are friction fit. what makes it really nice is that a 4’ flex hose fits it very well (albeit a little tight) and also blast gates. there is a 6” version also but one may have to find a distributor.
36 replies so far
View JK0702's profile
JK0702
138 posts in 2213 days
#1 posted 08-08-2012 10:38 PM
Mark-
I have been doing the mental gymnastics of a similar system for my shop. I just haven’t been able to work out the EXACT details. How did your project come out? Does it work well, any leaks? What would you do different? It’s important for my equipment to be mobile in my (garage) shop, so the flex tubing would give me that. I’m familiar with the triple wall, as I’ve used it before to house sprinkler lines under my newly poured driveway. A couple questions for you:
1. How did you anchor the triple wall, if at all
2. How did you transition to your dust collector
3. Do you have more pictures
Thanks,
John
-- John - Huntington Beach, CA --- Growth occurs when we get out of our comfort zone.
JK0702
#2 posted 08-08-2012 10:39 PM
Mark-
Thanks,
John
View whitebeast88's profile
whitebeast88
4128 posts in 2272 days
#3 posted 08-09-2012 12:38 AM
mark thanks for the info on the triplewall.i’ve just purchased a dust collector and now trying to design the layout and decide on the most economical way to.
-- Marty.Athens,AL
View robdem's profile
robdem
380 posts in 2688 days
#4 posted 08-09-2012 12:53 AM
Mark I used the same material in my shop few months ago to set up my dust collector stuff works great . Only used flex hose to hook up to machines. I have the pipe running to my table saw jouner bandsaw sanders and a drop down by my bench for planer and router table also have a hook up for miter saw . I used foil tape on al lthe joints along with clamps and pvc adhesive no leaks in the system
View jimmy J's profile
jimmy J
229 posts in 2460 days
#5 posted 08-09-2012 02:02 AM
1 I didn’t anchor the tubes at all. they just run along by basement floor. I suppose whatever technique that works for other tubing would work here.
2 see photo for transition to the collector. The triplewall tube will fit snugly around the exit dust ports on my machines and on the dust collector, so you don’t need anything extra.
in this first photo, to the collector, i raise it off the floor with a couple of 45’s.
in the second photo, from my jointer, the tube connects directly to the out port and also the intake of the blast gate. totally friction fit. at the left of the photo you can see the 4” flex tubing fitting over the triplewall. this joint was a bit tight, but it is how i would recommend doing it. i alloted enough flex here so i could move my jointer around. the other end of the flex connects into a short piece of triplewall which goes directly into a whye joint and into the main system, which you can see in photo three.
photo three
none of these joints require any additional tape whatsoever. i did tape all the triplewall to triple wall joints as there is some minor gaps here which i don’t think material. but it was easy to do.
in the forth foto you see the ultimate cheap maneuver. here i attached some spare vaccume hose to an end segment of triplewall (the female fat end). this then fit into another whye. this is what i use to vacume the shop. i can take that out and put on the cap seen on the floor when not in use (could have used a blast gate if i had an extra). this is also the place where i plan to connect to my smaller tools.
View Sawkerf's profile
Sawkerf
1730 posts in 3150 days
#6 posted 08-09-2012 02:07 AM
Yes, the flex will be cheaper than any of the solid wall ducts, but you lose a lot of collection effeciency. Flow in smooth walled duct is much better than in a rough wall.
View Tedstor's profile
Tedstor
1643 posts in 2714 days
#7 posted 08-09-2012 03:15 AM
Thanks for pointing this out. The hose on my DC is getting pretty tattered. Triplewall should be a perfect replacement.
View jmos's profile
jmos
847 posts in 2451 days
#8 posted 08-09-2012 12:22 PM
Interesting product, haven’t seen it before. Have you put a vacuum on it; does it hold up well? Does it come in 6”? Is it smooth inside; it looks a bit irregular outside?
I’m in the process of installing DC in my shop as well. It took some looking but I finally found a mom & pop shop that had the thin walled PVC sewer and drain pipe, $18/10ft for 6”, still quite a bit more than this stuff.
-- John
Mark Shultz
#9 posted 08-09-2012 01:24 PM
the company makes a 6” version, but HD does not stock it in my area.
it seems durable to me. will be under light wear relative to a drainage application.
the inner and outer wall are slightly undulating – not anything as rough as black irrigation tubing. the bumps are about 1/64” high each (i didn’t measure it). its been a while since my last aerodynamics course but i doubt there will be meaningful incremental drag over the distances a hobbyist would be using in their shop. the mfg may quote a Reynolds number if somebody wanted to research that a bit.
View jmos's profile
jmos
#10 posted 08-09-2012 02:59 PM
Interesting. I’ll have to keep an eye out for the stuff.
The manufacturer might have a friction factor for the material, or a roughness; you would use one of those coefficients, along with the flow and the properties of the fluid, to calculate the Reynolds number.
-- John
View ForestGrl's profile
ForestGrl
450 posts in 1167 days
#11 posted 06-10-2015 02:03 AM
I’m using this idea for the new shop configuration, picked up the pipe and various fittings today at Home Depot. Can’t figure out, though, how Mark and Jimmy got the hose to fit over the triple-wall. I’ve found another way to transition from hose to pipe, but would sure love to go direct without the extra expense. Any secrets or tips? The hose I’m using is the clear with black spiral. Blast gates are like the ones in the pictures above. TIA!
Also, what did you guys use to cut the triple-wall? I’ve been using power miter saw to cut Sched 40 PVC, but not sure about this triple-wall stuff.
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
View AZWoody's profile
AZWoody
1361 posts in 1305 days
#12 posted 06-10-2015 05:03 AM
on a 40’ run with 4” of this same pipe going from around 20’ to 40’ you will have a loss of 25% cfm.
I know, that’s what I used to run my whole shop and did my tests with my harbor freight dust collector with and without an oneida cyclone and no filter to see what the max flow I could get.
For my new setup, I’m going all smooth wall sewer and drain pipe.
jimmy J
#13 posted 06-10-2015 03:44 PM
to cut the triple wall, i just used a hack saw. it is a tight fit to get the hose on. i have bought the clear hose from Rockler and Woodcraft. I found the Rockler a little looser. the triple wall has a white outter, and black inner lining. to make the tube a little more malleable to ease a couple of connections, i took a box cutter to the black lining, then squeezed the white to make it fit. i also have various 4” machine ports. some of these fit great. some are a bit tight with the triple wall, but generally, the final connection for me was the flex hose.
jimmy J
#14 posted 06-10-2015 03:45 PM
AZ, would love to know the after CFM for comparison’s sake if the other parts of the setup are the same.
AZWoody
#15 posted 06-10-2015 04:08 PM
AZ, would love to know the after CFM for comparison s sake if the other parts of the setup are the same.
- jimmyhopps
It’s completely different now. I now have a 5hp motor with a 16” impeller running through 6” pipe now.
The problem I had, was that running 2 different types of separators with the same motor/impeller I was getting around 375 cfm at 20’ from the system. The dropoff was 25% at the 40’ mark which was my furthest point.
I needed to something larger because I do my own sawmilling of logs to lumber so I do a lot of drum sanding, planing and cutting more than most people so I produce a lot of dust. I was starting have some adverse health reactions so I bit the bullet and spent the money to upgrade.
showing 1 through 15 of 36 replies
