| Forum topic by clieb91 | posted 495 days ago | 266 views | 1 time favorited | 10 replies | ![]() |
495 days ago |
Topic tags/keywords: lathe tools lathe Hi All, seeing some recent posts has reminded that I bought a Lathe a few months ago and was able to get it into my basement workshop and back together in working order, but I have not done a thing with it. Witht he upcoming Anniversary sale at Woodcrafters I decided to spend my Christmas gift card on soem pen making supplies and hope to make a pen on my own lathe by next week. The numbers starting with 28 are the numbers on the tools. The rest of the handle reads ” Craftsman High Speed Steel” Any help anyone can give me in identfying which tool is which would be greatly appreciated. Thanks, Hoping to join the ranks of turners soon. -- Chris L. "Don't Dream it, Be it." |
495 days ago |
Sorry Chris, can’t help you here, I don’t have a lathe…well, I do kind of, my Dad bought a used one years ago and said I can have it…just haven’t gone all the way to get it. There are a lot of turner web sites out there though and magazines that are dedicated just to turning. The woodcraft guys should have classes as well. I’m with you don’t know very much at all about it other than they say start by practicing with a green log, yup that’s right green firewood. They say it’s the easiest to work with and learn. Not much but I hope it helps. -- Jim Hallada, Chesterfield, VA |
495 days ago |
Talk to the guys at Woodcraft. I have been to several in different cities and states. They are always helpful. From the looks of the tools displayed, you have more than enough to get started. You will need a sharpening system such as the Wolverine. You will also need a pen mandrel, drill bit, and the proper bushings for the style of pens you will make. Most beginners start with the slimline style. I would recommend taking a class through Woodcraft, reading books, watching DVDs, and checking out your local AAW wood turners club. They all are great resources. -- My favorite piece is my last one, my best piece is my next one. |
495 days ago |
1. Roughing gouge 1.A Where’s my Beer? <g> Cheers Bob -- A mind, like a home, is furnished by its owner |
495 days ago |
Chisel 1 is a roughing gouge -- Todd, Richfield MN |
494 days ago |
Chris, I recently purchased a used lathe. I got several DVDs along with the lathe. One of the DVDs was Titled Hand Crafted Pens – Then Basics. This DVD was made by Penn State Industries. I watched it last night. I found this DVD to be very helpful. Like you I have never turned a pen. The DVD takes you step by step through the process explained what tools were need and how to use them. I recommend you try and find a copy of this DVD as it is for the beginner. pkennedy -- P Kennedy Crossville, TN |
493 days ago |
For some reason the pictures are showing up right now but based on the answers above I can help a little bit. I’ve been turning pens for almost a year now. So keep that in mind as I’m certainly not an authority on the matter but I turned enough to know what works for me. The roughing gouge, exactly what sounds like, take it from square to the rough “cylinder” shape. Spindle gouge, used to “shape” your pen in to the basic profile you want. A lot people say you need a skew to turn pens, and I guess they are right, you don’t have to have it, but I do like to use for 1-2 passes before I start sanding. I also use a small round nose scraper where the wood meets the bushings to get an exact fit and small (1/4” I think) square nose scraper to make the tenons on the “Euro-Designer” pens. The way I got started was simply turning some scrap oak I had between the centers. Then moved on to some ash pen blanks (because ash was the cheapest blank I could find). You don’t have to get a drill chuck for the lathe if you have a drill press (at least not for pen turning). I use poly glue for my brass inserts and have not had a problem yet. I know most people use CA but the poly glue works better for me. The only hardware specifically for pens that I have seen mentioned is a milling bit to square the ends after you have inserted the brass tubes. Finally, you’ll want more than your usual safety glasses for turning. You’ll want something to protect your entire face. First you’ll find the wood flying off can be uncomfortable hitting you at a high rate of speed and when you start slinging different finishes off of there, they can irritate you as well. Nothing like a little CA on your face. And this may be obvious, but I’ll mention it anyway since the downside can be really bad is a dust mask of some sort. The fine dust on some of the exotic woods is really nasty on the sinuses. Hope this helps. -- Dad to 5, Son of The One |
491 days ago |
I bought a lathe last year as well, almost sent my tool into the ceiling and destroyed the piece of wood I was working on. Fortunately we have a local Rockler and they do turning classes, it is well worth the money, the hands-on experience with an experienced turner is priceless. You might also be able to find a local turning club where you can find an experienced turner willing to show you the ropes. -- Rich, WNY, www.nyrockingchairs.com |
491 days ago |
For free – here’s something I found useful when I started with my lathe. Go to Project Gutenberg and search for a book called A Course In Wood Turning by Archie S. Milton and Otto K. Wohlers. It was written in 1919 but, you know what, the basics haven’t changed a bit! -- "Find out what you cannot do and then go do it!" |
491 days ago |
Believe me, you’ll never have enough tools of any kind, for the lathe or anything else so just find a good woodcraft lay your money down and start buying anything related to the lathe, then you’ll have it all covered. Don’t forget the “how to” books and the “what you need to buy to succeed at the woodlathe” books. Then you’ll be all set. I’m just kidding. Welcome to LJs. Yea! Martins Gone! Lets raise heck! -- Mike. mwurm13@yahoo.com |
488 days ago |
Hey All, Thanks for the information it is greatly appreciated. (EE thanks for that gutenberg tag, as a history buff I love looking at those kind of things for ideas) I picked up some items at the sale this past Saturday and planning to get down to the shop this week. So hopefully by the end of the week I will post some type of finished Lathe project. CtL -- Chris L. "Don't Dream it, Be it." |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
258 |
955 |
226 |
Woodworking Trade & Swap
623 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
