Forum topic by 404 - Not Found | posted 08-07-2012 02:16 PM | 887 views | 0 times favorited | 7 replies | ![]() |
While it’s quiet out there, I thought I’d make a tv stand to fit in the corner. (This is exactly what the wife wanted so I didn’t deviate from the plan). What do you fellow Jocks think? Bite the bullet, do it all again, or plan B. Or is there a better way? I just want this gone as soon as possible so I can get on with a proper job. |
7 replies so far
#1 posted 08-07-2012 03:46 PM |
Renners, -- John @ http://www.thehuffordfurnituregroup.com |
#2 posted 08-07-2012 04:10 PM |
Thanks Huff, I used a black ‘synthetic enamel’ in a spray can – over a waterborne mdf primer sanded to p240. It was all looking silky smooth until I went over it with the acid catalysed satin lacquer – which is when this small problem area showed up. I think it’s more likely that the black enamel wasn’t fully cured under the lacquer than the surface was contaminated by anything. 99% of the job looked really good with the lacquer on, its just this one part of it, where it probably had more paint laid down on it. I’ll try the shellac to seal as your recommendation – it’s not something I’ve used much as you don’t see it over here. Thanks again |
#3 posted 08-07-2012 04:33 PM |
Leave it alone and hope the boss doesn’t notice? Glue a mouse pad over it and tell her that’s where the remote goes? I’m a lazy man in search of lazy solutions. :-) -- Charlie M. "Woodworking - patience = firewood" |
#4 posted 08-07-2012 04:47 PM |
Renner’s, You may be right about the black enamel wasn’t fully cured under the lacquer. If that’s the case, you can sand out the problem and repeat the process without trying to find a shellac. Allow extra time between the enamel and the lacquer and that should solve the problem. Another trick that works when putting lacquer over another finish, since lacquer burns in as it dries, would be to make sure you spray the first coat or two of lacquer on very lightly. The heavier the coat of lacquer the more time it has to burn into the finish below and in this case may create a blemish. As the coats of lacquer build, it will burn into itself instead of the enamel and you can spray a heavier coat on for the final finish. Hope I didn’t confuse you too much. Let me know if you have any questions. -- John @ http://www.thehuffordfurnituregroup.com |
#5 posted 08-07-2012 04:58 PM |
Charlie, I thought about a big doily, the kind like my Granny used to have under her cactus on top of the telly |
#6 posted 08-07-2012 05:16 PM |
Your grandma too, huh? That’ll work. -- Charlie M. "Woodworking - patience = firewood" |
#7 posted 08-07-2012 05:36 PM |
Scuff sand the entire project lightly, strip sand the bad area, prime, wait for the primer to cure, paint, same thing, feather it in, when you are satisfied with the paint and it has FULLY cured, apply a urethane clear coat / gloss or clear gloss spray lacquer of some sort over the entire project. -- Please like and subscribe to my YouTube Channel https://www.youtube.com/c/daves-workshop |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2103 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8842 |
