Router newby help
Forum topic by Brett posted 08-07-2012 01:21 PM 772 views 0 times favorited 2 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2554 days
08-07-2012 01:21 PM
I need to make a 5/8” groove, 1” deep, several feet long, in the underside of a workbench.
Can I use make multiple passes with a straight bit, or do I need to buy a upcut spiral bit?
-- More tools, fewer machines.
2 replies so far
View richgreer's profile
richgreer
4541 posts in 2946 days
#1 posted 08-07-2012 01:28 PM
Yes, you can do this with a simple straight bit. In fact, that may be the preferable way to do it. I say that because with some wood, an upcut spiral will create a little more tear out at the edges.
I would recommend taking no more than 1/4” with each pass and keep moving at a slow but steady pace. If you stop, you will create a burn mark.
Finally, nothing is more important that using a sharp bit.
View Tenfingers58's profile
Tenfingers58
96 posts in 2549 days
#2 posted 08-07-2012 01:34 PM
I’d do it in several passes with a straight bit. Same thing if I was using a spiral bit. It’s about how much wood you’re removing at one pass, you don’t want to overwork your router. You also don’t want to travel too slow. (leads to burning)
I usually travel about a foot in ten seconds. If the router slows too much I lessen the depth of cut, but keep the feed rate up so I don’t burn.
