Tough spot!!!
Forum topic by bigike posted 08-07-2012 01:22 AM 804 views 0 times favorited 4 replies Add to Favorites Watch
View bigike's profile
bigike
4053 posts in 3195 days
08-07-2012 01:22 AM
Topic tags/keywords: box woodworking
I got a box I’m doin and it’s an octogon shape the top is 3/4 thick I wanna scoop out about 1/4-3/8” and leave a 1/2” lip how would u do it? I only have the basic tools routers, TS, drillpress, 12” bandsaw, etc.
View nwbusa's profile
nwbusa
1021 posts in 2193 days
#1 posted 08-07-2012 03:06 AM
Starting from the center, use your router to remove material, working your way toward the outside of the box lid in an outward spiral pattern. Make a template that fits around the perimeter of your octagon to act as a “fence” or stop for your router base, so that your router stops cutting 1/2” away from the she of your box edge. You’ll need to use a chisel to clean out the eight inside corners of the octagon as the router bit will leave them rounded.
-- John, BC, Canada
nwbusa
#2 posted 08-07-2012 06:49 AM
That was supposed to be ”...the side of your box edge.”, not ”...the she of your box edge.”, but you probably got the point anyway.
Stupid iPad :p
-- John, BC, Canada
bigike
#3 posted 08-07-2012 10:35 AM
I got tha fence but no way to mt or stabilize it to the top it’s 1/2” thick by 7/8” wide. I’m using a core box bit or round nose to get the rounded corners to make the top look an feel lighter.
bigike
#4 posted 08-07-2012 10:12 PM
I got some info from my boss I’ll try it an post it.
