How close is close enough?
Forum topic by javaboy posted 08-06-2012 08:25 PM 1104 views 0 times favorited 8 replies Add to Favorites Watch
View javaboy's profile
javaboy
104 posts in 2005 days
08-06-2012 08:25 PM
Topic tags/keywords: question tablesaw machine setup alignment calibration extension tables
I took delivery of a new Grizzly G1023RL tablesaw late last week and have been slowly cleaning it up and assembling it. I used a precision straight edge to line up the cast iron table extensions, but it seems no matter how much I fiddle with it, I can’t get them completely, perfectly flush with the main table. The best fit allows a very thin piece of paper to slip between the straight edge and parts of the tables—some parts are perfectly flush, but others aren’t. This obviously means the tables are not perfectly flat. So my question is, how close is close enough? Should I expect total perfect flush alignment of both wings along their entire length? Or is a little imperfection no greater than the thickness of a thin piece of paper here and there OK?
This is my first experience with a “good” tablesaw, so I really don’t know what to expect.
-- Sow justice, reap peace
8 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 2939 days
#1 posted 08-06-2012 08:34 PM
Your side tables might be flat and the problem is where they bolt to the main table. If everything were dead-nuts flat on top, but the edges were slightly off of 90*, you would see this problem. Nothing is ever perfectly flat or square so it’s up to you to decide if you can live with a slight mismatch. Remember that you’re a woodworker – not a tool and die machinest. – lol
When I set up a table, I use a long straightedge to bring the outer edge of the side tables up to the level of the main table. If the inner edge is high, I make it even and let the outer edge be a tad bit low.
View Sailor's profile
Sailor
543 posts in 3136 days
#2 posted 08-06-2012 08:42 PM
I think you will be fine. I have the exact same saw and mine isn’t perfect either.
There is no way that much of an offset could really effect your work. I say enjoy your new say! It is a “good” one for sure!
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
View Doss's profile
Doss
779 posts in 2135 days
#3 posted 08-06-2012 09:06 PM
If I’m reading this correctly, you’re worrying about .004-.01” of height difference. I’m thinking you’re going to be fine if that’s true.
Where are you high and low? That could determine what to do next.
Otherwise, how much money and time do you have? Someone could get it closer if you have lots of both.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View knotscott's profile
knotscott
7819 posts in 3246 days
#4 posted 08-06-2012 10:42 PM
The proof is in the pudding. If the saw cuts well, you’re good to go….which I suspect will be the case. Blade selection and blade alignment are the areas to get picky about, but it’d take a pretty sizable deviation in just the right spot for table flatness to effect anything.
View Tedstor's profile
Tedstor
1643 posts in 2503 days
#5 posted 08-06-2012 11:21 PM
I think you’re OK. I’m sure the extensions are far flatter than the wood you’ll be cutting.
View crashn's profile
crashn
528 posts in 2336 days
#6 posted 08-07-2012 12:05 AM
my router wing sits about .002 below the main saw table, works fine and has not affected precision.
-- Crashn - the only thing I make more of than sawdust is mistakes
View teejk's profile
teejk
1215 posts in 2555 days
#7 posted 08-07-2012 12:06 AM
I would think that you don’t want the extensions extending above the saw table itself (they probably pay most attention to that at the factory). Other than that, you’ll be fine.
javaboy
#8 posted 08-07-2012 12:30 AM
Thanks everyone for your input. Since I never had any experience with a cabinet saw before, I didn’t know what to expect—had no idea that anything less than absolute perfect flatness was acceptable.
