Spraying water based finish problems (Help)
Forum topic by simpsy posted 285 days ago 522 views 0 times favorited 5 replies Add to Favorites Watch
View simpsy's profile
simpsy
28 posts in 595 days
285 days ago
Topic tags/keywords: walnut maple finishing spray gun
Hi everyone I have just started to finish up my walnut and maple serving tray that I have been working on for a while. To practice my finishing techniques I took my finish of choice (General Finishes Exterior 450 outdoor varnish) and used my critter sprayer and began to practice on a scrap piece of lumber. The finish is nice and smooth after 4 coats, but the only thing that is kind of annoying me is you can see the finish is almost specked in appearance, it is not an even sheen as I would like. I would not be totally upset if this finish was on my serving tray but I would rather it be an even sheen with no speckles. If anyone has any tips on spraying the finish or maybe tips for after spraying it to fix this problem I would really appreciate it.
thanks Greg
5 replies so far
View pintodeluxe's profile
pintodeluxe
1733 posts in 979 days
#1 posted 285 days ago
Can you elaborate on the sprayer? I have not heard of a critter sprayer.
If my gun is clean, and will spray thinner well, but is having trouble spraying thye finish—- then the finish likely needs to be thinned 10%. Otherwise, changing tip and nozzle sets on HVLP sprayers can help.
simpsy
#2 posted 285 days ago
View NiteWalker's profile
NiteWalker
1467 posts in 743 days
#3 posted 285 days ago
Try lowering the pressure at the compressor.
I have a critter gun too and the key is to set it at the lowest pressure that gets the job done.
I got decent results with the critter, but wasted a lot of finish because of overspray.
What I ended up doing was splurging on a QS-125WB with bigger cup from homestead finishing. It’s an hvlp conversion gun and is lightyears ahead of the critter.
pintodeluxe
#4 posted 285 days ago
After seeing the gun, I would recommend the Woodriver (Woodcraft) Gravity-Feed HVLP gun. The gun sprays an excellent finish and amazingly costs less than $40.
Porter Cable offers a nearly identical gun with a regulator for a little more money.
See my reviews if interested.
simpsy
#5 posted 285 days ago
Thanks for the advice everyone. As for my problem, I toned the psi down and layed a little heavier coats. Looks great! THANKS AGAIN
