Crematory Urn
Forum topic by Handtooler posted 293 days ago 591 views 0 times favorited 7 replies Add to Favorites Watch
View Handtooler's profile
Handtooler
399 posts in 304 days
293 days ago
Have any of you experienced fine woodworkers constructed/fabricated/assembled/or built a wooden crematory urn suitable foor placing in a niche? I have some general deminsions, but I don’t know how the top fits on or into the carcus. All pictures I’ve seen do not show dovetailed joinery, but appear to be possibly lock miters or locking rabet/dado joints.
Any help or suggestions will be certainly appreciated. Russell
-- Russell Pitner Hixson, TN 37343 bassboy40@msn.com
7 replies so far
View Pimzedd's profile
Pimzedd
334 posts in 1976 days
#1 posted 292 days ago
There are a number posted here on Lumberjocks. Just type in Urn in the search boc up above. Good luck.
-- Bill - Mesquite, TX --- "Everything with a power cord eventually winds up in the trash.” John Sarge , timber framer and blacksmith instructor at Tillers International school
View Howie's profile
Howie
2449 posts in 1095 days
#2 posted 292 days ago
I have built a number of these.
General dims are 1 cu/in for a pound of body weight. I just make mine, size wise, something pleasing to the eye.
Joints are typically up to you. I’ve used lock miters,DT’s thru and hidden,plain miters pinned,box joints.
Mine are fixed lid with the bottom being inset/rabbit and brass screws for access.You can seal the joints inside with silicone if you wish.
I’ve used cherry,walnut and poplar. Wood choice there again is up to you.
Tops are with a brass plate and anything else you desire.
Hope this helps.
-- Don't rollerskate in a buffalo herd
View David Kirtley's profile
David Kirtley
1250 posts in 1170 days
#3 posted 292 days ago
Not meaning to be crude or disrespectful, the lid isn’t much of a problem. It is not something that will be opened and closed a lot. just a plug that fits in the top or a lip around the outside should be fine.
The cremains that I have seen have been delivered in a sealed plastic container so, barring a lot of handling, should remain intact without relying on the tightness of the joinery. I would suggest basing the urn to hold that as I don’t even want to imagine the trauma of someone being down sweeping up the remains of a loved one if the urn suffers an accident.
View shipwright's profile
shipwright
3400 posts in 970 days
#4 posted 292 days ago
I used a sliding dovetail with a locking pin on my mother's urn Russell.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
View Jamie Speirs's profile (online now)
Jamie Speirs
3685 posts in 1029 days
#5 posted 292 days ago
We make them with a removable base
That way you have plenty of scope for
the top.
They have to be opened once to take out
Some ashes for the Tsa Tsa & blessing.
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View huff's profile
huff
2559 posts in 1457 days
#6 posted 291 days ago
I’ve made a number of urns and I’ve always made the top part of the box itself and made the bottom removable. I’ve always left the remains in the sealed container I received from the creamatory and design to allow enough space to insert the container. Design and jointery is totally up to you. This is very personal woodworking so just make it from the heart and it will be perfect.
-- John @ http://www.thehuffordfurnituregroup.com
Handtooler
#7 posted 291 days ago
Thanks to all who have provided comments. I’ll be sure to consider them as I begin my work. Russell
