Can anybody identify this router please?
Forum topic by moshel posted 77 days ago 230 views 0 times favorited 8 replies Add to Favorites
View moshel's profile
moshel
132 posts in 165 days
77 days ago
Topic tags/keywords: router old
black and decker HD 1250 or something
this was advertised as black and decker HD 1250. google search for this model shows that few people really have fond memories of this router, but no specification. it looks VERY solid.
I won this on an auction and going to pick it up in the next few days. if anybody knows what I should look for or even (as someone told me a few minutes ago) if this might be a 3/8” router.
-- The woods are lovely, dark and deep, but I have promises to keep...
moshel
77 days ago
oh, forgot to mention – i plan as using it for router table.
View Dusty56's profile
Dusty56
1159 posts in 169 days
77 days ago
first one I’ve ever seen : ) Hopefully you won’t be limited to 3/8” bits….I have an old Craftsman that looks about this size but takes 1/4” bits only…Best wishes
-- Dusty56@comcast.net
View John Ormsby's profile
John Ormsby
157 posts in 218 days
77 days ago
You would be much better off buying a more popular well built router. Off brand or rare electric tools will only cause frustration for the user. You will definitely not want this router if it is 3/8”. Bits normally come in 1/4” and 1/2”. There are also some 8mmm bits. I use all three. I have never seen or used a 3/8” bit.
-- Oldworld, Fair Oaks, Ca
View Festool4's profile
Festool4
54 posts in 259 days
77 days ago
I haven’t seen this model before, but the base is very similar to a Dewalt DW610. Dewalt and Bosch use the same treads on their collets. Hopefully, this router will be the same. I would take it to a local woodstore and see if you can come up with a replacement collet.
-- Festool4
1942 posts in 502 days
77 days ago
Moshel, please don’t spend your time building this old fella into a table.
It looks like the old 1/4’ shaft style collet and you will accumulate a bunch of 1/4” shaft carbides that you will probalby never use once you find out about 1/2” shanks.
Why? Cause they slip and grind up your collets if you’re not extremely careful and #2. you can’t find all the bits you will want to use with 1/4” collets.
It will probalby be usefill around you shop as a hand ehld machine for laminate trimming or round overs etc.
Cheers
View Loren's profile
168 posts in 129 days
77 days ago
It’s very similar to a DW610 – a router that has sort of
gone out of style but is still a very solid tool.
I have a 610 and about 5 bases for it… but depth adjustment
is NOT refined compared to the routers we have these days,
though it doesn’t suffer from concenticity errors you may find
in the PC other routers that twist in the base.
What is peculiar here is the large “growths” on either side of the
top of the tool. The 610 is a beefy router but does not have
these things sticking out. My guess is it’s either quite old or
intended for some special use.
Black and Decker made an industrial line of routers for awhile -
and they were good quality.
Unless it’s a 1/2” shank router or it’s under $20 I would probably
pass on it… but I already have several routers and don’t need
another.
I used my DW610 in a table for a long time and it was an excellent
performer with 1/2” shanks. The collet always seizes the bit so
if I want to change the cutter I have bang on the collet nut with
a hammer until it releases. I’m used to doing this so it no longer
annoys me – but be prepared for this.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online business building
moshel
77 days ago
First, i love old solid machines. second, this was sold for ~40$. Oh, well – i’ll wait and see if its 1/4” or 1/2”. I have two other makitas (one of them old, one new), so this is not my only router. however, both my makitas are plunge and they are not really good under the table.
moshel
77 days ago
Thank you all for trying to identify the beast. strange thing on the top of the router are very strange – couldn’t think of anything that might be hiding there. Oh, well – i’ll see.
Bookmark And Share This Page
