Router table: How big is big enough?
Forum topic by DanM posted 39 days ago 240 views 0 times favorited 9 replies Add to Favorites
View DanM's profile
DanM
55 posts in 152 days
39 days ago
Planning to build a router table for my Hitachi M12V. I have a glue up for the top, 24×30 x 1.5. I see many (or at least SOME) commercial tables are smaller than this. If nothing else, a smaller table would take up less space. Is there any real advantage to a bigger table on one of these, like with a wider/longer jointer, wider planer, etc., etc., or is there a point less than my 24×30 which is big enough?
TIA
Dan
View MVWOODWORKS's profile
MVWOODWORKS
130 posts in 157 days
39 days ago
24×30 is a good size. Many after market tables are that big. Keep us posted.
-- Pat, Colorado
View pashley's profile
pashley
247 posts in 160 days
39 days ago
I have that same router, which is nice. My router cabinet is quite large, probably close to that size. I found that the width is good, but it’s really too deep for what I need. I think my router is about 10 inches from the front edge-plenty enough.
-- -Be Blessed!, Patrick
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
164 posts in 40 days
39 days ago
I included my router table in the outfeed table for the table saw, so mine is 48” x 64”, with the router bit about 20” in from the long edge, centered on the long side. I also use a 24” x 30” portable table that I can clamp to saw horses.
-- Rich, WNY, www.nyrockingchairs.com
View Tim_456's profile
Tim_456
7 posts in 38 days
23 days ago
I’m probably the oddball here but my router table top is big, I made it from a 2ft x 4ft piece of MDO with a plywood box under it to house the router and provide a stable base. The router is on one side of the table, centered and about 10 inches from the edge. The table top is on a set of hinges to get into the box under it. The box is divided into to compartments, one for the router, the other as general storage. Anyway, I kept the table long so that I could route longer pieces. As this was my first router table I didn’t know what I needed.
I also made two fences, a 5 foot fence for long pieces and a 2.5 foot one for normal, everyday routing. 99% of the time I use the short end of the table so I could get by with a 2×2ft table. However, I’ve routed some custom moldings and edges on long pieces where it helped to have the longer table. It kept the long and narrow pieces under control. I’ve also used it to put rabbits on longer, larger pieces.
For me, I enjoy the larger table, but only because I already have it. If I had to do it again I would make it closer to 2ft deep x 3ft with the router set towards the back. This would give plenty of support for the piece and the fence but without taking up way too much space.
4800 posts in 293 days
22 days ago
Mine is built into the end of my tablesaw. Has been adequate to date.
View Blake's profile
Blake
1874 posts in 317 days
22 days ago
It really depends on the type of fence you will use. I really like Incra fences, which require a much bigger table top. Mine is 32” x 44”
Click for details
-- Dust collectors suck.
View daveintexas's profile
daveintexas
176 posts in 318 days
22 days ago
I have to agree with Blake. I too have the Incra fence (older model), but you do need the wide/deep table.
And I have the same router as the OP, its a real work horse, I am on my second one in seven years. Bearings went out of the first one.
Post pics when done
-- MISSION FURNITURE-My mission is to build furniture
View GaryK's profile
GaryK
8401 posts in 431 days
22 days ago
I started out with one about 30” wide, but then got a Incra fence like Blake shows and I had to add a “wing” to the side of mt table to fit it. Too much work to remake the top at this time. Probably will later.
The bigger the better if you have the room.
View DanM's profile
DanM
21 days ago
Well the top is done, it’s 34×24, 1.25” MDF w/ high pressure laminate on all sides/edges. Router is 8” from one long edge. Fence is done, also. After considering t-track, I went with the built-in edge clamps ala Hylton’s books, to eliminate a groove & make it easy to flip the fence to use on either the wide or narrow sides. Next step is to install some 1.5×2.5 plywood strips I glued up & machined nice & straight to the underside for flattening/bracing, then enclose the router area for DC purposes.
Mine’s not going to be nearly as slick as the ones with drawers etc. At least not at 1st. Depending on just how embarrassingly ugly it turns out on its framing lumber legs, I might post a pic ;-)
Thanks for the replies.
Dan
Bookmark And Share This Page
