Breadboard design for Butcher Block Table Top
Forum topic by vrice posted 08-04-2012 04:14 PM 6677 views 0 times favorited 11 replies Add to Favorites Watch
View vrice's profile
vrice
101 posts in 2595 days
08-04-2012 04:14 PM
Topic tags/keywords: question joining maple butcher block
I’m in the process of designing a kitchen table/island/ that has a hard maple butcher block top. My design at this point is this:
I REALLY want a contrasting wood border on the top. After designing this in I came to the realization (a little research here on LJ) that just gluing this onto the butcher block won’t work due to wood movement. Researching this further I discovered the breadboard concept. However, all the examples of this I saw involved border-less tops with the breadboard on the ends of the table. Again, I wanted a border all around the perimeter of the top. The other noticeable aspect of these breadboard setups was the tenons were always on the table top with mortises in the end pieces. Since I’m working on a border here I didn’t want to have to make the border the width it would take to accommodate a mortise, say 1.25”. I wanted the border to be only .75”. So I came up with this design:
The mortise is in the top and the tenon is on the end piece. The tenons have elongated holes at the ends that will accommodate a .25” of wood movement. In addition the tenon holes are offset 1/32” to make a draw bore joint. In addition I designed a dowel connection (no glue in one of the mating ends of the dowels) to both “connect” the ends of the end piece to the other trim but still allow for movement in the whole thing.
I’m new to this breadboard stuff. I’ve purchased all the wood for this thing (not cheap) and I don’t want to screw this up. So I’m looking for some sage wisdom/advice for the LJ community here. Will this design work? Is there a better way to do this?
-- Vic Rice
11 replies so far
View Handtooler's profile
Handtooler
1497 posts in 2036 days
#1 posted 08-05-2012 05:20 PM
My family has had and currently uses a similar design in our home. Because we a short people,5’1” an 5’ 5” ours is 31” off the floor and incorpoorates casters to allow for movement and cleaning behind. We have two large deep pullout shelves, or drawers with narrow sides in the lower area where you show openings. These have doors and are used to store the mixer and other tools/utinsiles used in food prep there. It includes a two position female electrical box andoutlet in one end that allows for power from a low wall outlet behind to be used by appliances without having to incorporate extension cords draped to other outllets accross the room. “Hazard Prevention” especially for children. Good job of designing. Ours does not use a border, but a friend has one designed after ours and used sliding dovetails mitered at the corners. Russell
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Chadster's profile
Chadster
20 posts in 2101 days
#2 posted 08-05-2012 07:52 PM
Looks cool, I wonder if they would open or cause problems where the ends are dowelled…but moving freely ?
Could you just run the ends pass the sides as an alternative? It would be more of a standard breadboard end look, but with still the border to match…
I like this design and have been thinking of something similar to this for our kitchen.
-- If it's worth doin', it's worth doin' right.
View bondogaposis's profile
bondogaposis
4598 posts in 2255 days
#3 posted 08-05-2012 08:46 PM
If you forgo the draw bore joint it will work. I’m thinking that the draw bore will prevent movement and may split the tenon.
-- Bondo Gaposis
vrice
#4 posted 08-05-2012 10:16 PM
Great comments.
Handtooler, I gave some thought to the sliding dovetail idea originally. Quite frankly, I suspected I was less likely to screw up the mortise and tenon than a sliding dovetail. And my thought about mitered ends was how does one explain the gap at the joint to accommodate movement? Makes it look like a lousy joint to the uninitiated. Just my vanity talking I suppose. That was kinda what I was trying to do with the dowels. Put something interesting in there that would highlight the gap was intentional.
Chadster, this did cross my mind as well. The worry I had with that approach was something catching on the edge of the wood, at the gap, and ripping the trim off, probably small probability of that happening.
Bondo, I was wondering about this. I did find several other breadboard designs on LJ that claimed to use this draw bore technique. I suppose if you get the pinch tight enough you’re point is definitely valid. On the other hand, since this thing will have no glue there needs to be some drawbore effect, doesn’t there. If not seems the end piece would have some play potentially.
-- Vic Rice
bondogaposis
#5 posted 08-06-2012 03:33 AM
My thinking has to do w/ the fact that a normal draw bore is on a tenon where the grain runs differently than what you are proposing here. You will want the fit to be snug for sure, but I would be afraid that too much pressure will cause a split that will run with the grain.
-- Bondo Gaposis
Handtooler
#6 posted 08-06-2012 09:15 AM
Ours has no border, and I’m kinda glad; as any gaps due to movement would possibly allow food stuff (oils and greases, flour and such) to miagrate there and be very difficult to keep clean. That trim is beautiful and really sets it off, but ya know butchers never had trim on thieircutting blocks and scrubbed them a couple times a day. Not finding fault, just being the devils advocate. Russell
vrice
#7 posted 08-06-2012 12:22 PM
AH! Bondo you are absolutely right. I hadn’t thought about that. Hmm….......................
-- Vic Rice
vrice
#8 posted 08-06-2012 02:59 PM
Yeah, Russell, good point about food getting trapped….................................
-- Vic Rice
View BTK's profile
BTK
8 posts in 2051 days
#9 posted 08-10-2012 01:56 PM
Vic, if you don’t mind a separate question. I’m building a butcher block island table right now too. Top is done, leaving it simple 2 1/4 think hard maple. No end caps, might contrast with the finish on the support.
My support is like the Kirby bench. So, how are you attaching you legs to the top?
Thanks
vrice
#10 posted 08-11-2012 02:45 AM
BTK,
I just plan on using one of the several techniques for attaching the top while allowing Movement. I am leaning towards figure eight clips. Check this out.
-- Vic Rice
vrice
#11 posted 08-17-2012 02:39 AM
OK, I’ve given this some thought given the point Bondo made. I am going to change my design a bit. The end caps will not have a tenon. Instead I will use floating tenons, made of hard maple, with the grain oriented parallel with the table top grain. To wit:
Any comments on this approach??
-- Vic Rice
